Home > Technical (L322) > Air compressor |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1185 |
Any help or pointers, I fitted a new Dunlop compressor to my 2011 4.4 as I was getting the compressor overheating info from my IID tool and the usual yellow triangle with bong then red triangle, do not exceed 30mph.
30th Sep 2018 9:52pm |
After a few messages like before things settled down and are working well before I changed the compressor I renewed the front ride height sensor as I had a message come up with the IID tool that was the problem? I don`t think it was because I still had to replace the compressor.
17th Apr 2019 8:15pm |
Baz1975 Member Since: 26 Nov 2013 Location: Newtownabbey Posts: 55 |
Yes, just made a post there.
17th Apr 2019 8:50pm |
Do you have an IID tool? I know of I, RST Landrovers Ltd, 1-3 Kingsland Road, West Mersea, Essex, CO5 8RB or a couple in Kent
17th Apr 2019 9:06pm |
No, I don't. I'm hoping my sons mate will call in over Easter & connect his up.
17th Apr 2019 9:19pm |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 89 |
If you changed the compressor type from old (Made by Hitachi) to new (made by AMK) you need to reflash the suspension with the IID tool. This could be a reason for your problem (assuming the physical parts and bits are ok) 2008 HSE B. Grey
19th Apr 2019 1:46pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
This type of behaviour is exactly what mines doing now but thats because of it needing a new air bag on the front offside. If I put the suspension on high I can hear loads of air escaping. On access height or normal it's fine, no air leak etc until I hit a bump or accelerate, it then sounds like a lorries air brakes, not sure if thats what you meant by pulsing.
19th Apr 2019 2:24pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Tinman, did you resolve your issue?, as I'm having exactly the same problem.
28th Apr 2019 6:47pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 887 |
Im changeing my front off side bag this week iv a leak get in there with some soapy water
28th Apr 2019 7:52pm |
Dave, had a good look & squirt, no bubbles. Did it at Normal height, any advantage of doing it at off road height (although I suppose it wouldn't hurt). Good luck with yours. |
29th Apr 2019 6:53pm |
yelnats69 Member Since: 21 Dec 2019 Location: Dymchurch Posts: 35 |
Did this cure your problem |
17th Jan 2020 9:14am |
