Home > Technical (L405) > L405 ARC squeal / hiss when cornering
Triggers Broom
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hello all, just joined and first post so bear with me!
Recently bought a 2014 RR L405 4.4 V8 diesel SE from LR so have a 2 year warranty thank goodness.
Only had it a month and already had the compressor and valve changed!
May be a problem with the ARC self leveling system as it seems to squeal / hiss a bit when cornering, worse when cornering to the right. Going round a roundabout for example it squeals a bit. LR say its all ok and no faults but I have my doubts.
Any thoughts / views would be appreciated? Anyone experienced this?
Post #488697 11th Sep 2018 6:15pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
hello and welcome! Thumbs Up
do you have deployable side steps ?
If so... then yes the noise is coming from the ARC valve and is cause by pipes vibrating on the mounts for the steps. The pipes should have rubber spacers (snubbers) fitted when the steps are added to the car (even if the steps were added when the car was new - they are a dealer fit and not done by the factory) - sometimes they don't bother fitting the spacers, sometimes they drop off.
See
http://www.fullfatrr.com/forum/topic45065.html
The spacers are only a few quid and easy to fit. Note that even when fitted, there will still be a very very slight noise but it should be MUCH improved.
I can email you a copy of the TSB mentioned in the above thread if you need it.
fleagle.
Post #488740 12th Sep 2018 10:17am
Triggers Broom
Hello and thank you for your quick reply! Yes I do indeed have deployable side steps so I'll get that checked out.
If you could email the TSB that would be fantastic. Will keep you updated.
Much appreciated!
Post #488744 12th Sep 2018 10:40am
Triggers Broom
delete
Post #488747 12th Sep 2018 11:01am
Fleagle_UK
did you get this resolved ?
Post #490814 3rd Oct 2018 1:40pm
Triggers Broom
Its going into the garage next Tuesday to have the work done as per the Land Rover TSB. Will let you know if it works!
Thanks
Post #490825 3rd Oct 2018 4:39pm
