![]() | Home > Group Buys > Reversing LED bulb (CanBus) |
Blueboy1 Member Since: 11 Oct 2016 Location: Cumbria Posts: 15 ![]() ![]() ![]() |
Hi Bushy
CY88 Member Since: 05 Feb 2015 Location: Offshore Posts: 14 ![]() ![]() |
Hi, just registered if you have any left? Ta. |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
PM's sent to both Current: 2011 FFRR Vogue SE 4.4 TDV8
Hi, received the bulbs today and changed them - worked great for all of two minutes and then both failed. Bulb error on diagnostics which needed to be cleared with GAP tool, now the LEDs will not work at all? When I put one LED in with a normal bulb and it cuts the power to both. Any ideas? |
Hello Sir,
I don’t think it’s the fuse, as when I put both the old bulbs back in all works fine again |
Ok, well not the fuse then.
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 89 ![]() ![]() ![]() |
Hi Bushy
pawsinmud Member Since: 26 Mar 2019 Location: Hampshire Posts: 34 ![]() ![]() ![]() |
Hello
Hi John,
Thanks Bushy, I will definitely have a pair when you do.
Hozza12163 Member Since: 10 Sep 2019 Location: Bedford Posts: 51 ![]() ![]() ![]() |
Can I nominate myself for 2 pairs please |
I ordered the COB lights as well, just in case! |
You can always mount both - then it will be bright |
