Home > General > How fragile is the L322 when it gets "old"
Vogue
Tim,
I had something similar with a RR Classic 25 years ago, the car ran normally, but unfortunately 6 months later the rubber bit was sucked up into the fuel pick up pipe causing very bad fuel starvation.
The engine would run, but the car wouldn't drive - I was stranded 35 miles from home - not good - resulted in the fuel tank having to be dropped off the vehicle and the offending part removed from the pick up pipe.
Guess with yours, its somebody elses problem now though Shocked Cool
Post #51689 24th Feb 2011 9:40am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Is this a trick question?
The FFRR won't be "Old" for at least another 15 years... by which time it will have outlasted the seemingly acceptable UK Scrapage scheme by a factor of 2.5 but still won't be "old" by comparrison to the survival rates of the rest of the Landrover line up.
Now then If the question referred to "Unfashionable" or "beyond economic repair" thats a different bag of spanners. Whistle
Of course as Petrol will be £50 a gallon in 15 years its all accedemic as we'll all be passing our stationary Range rovers on our way to work... on our donkys... Of which LPR and Gaz will have a fine line up should we wish to trade up Laughing 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #51691 24th Feb 2011 9:47am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Vogue wrote:
Tim....... Guess with yours, its somebody elses problem now though Shocked Cool
Well it isn't mine which is the main thing - at least I can rest assured it wasn't you who bought the car as that TD6 was a Monte Carlo Blue and they were not too comon
El - old to me = on it's second or 3rd owner.................. Whistle Whistle 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #51697 24th Feb 2011 10:16am
M44K TS
Still gearbox related, I called the local LR service centre and asked about getting the gear oil flushed/replaced, as expected, they said it's a filled for life gearbox, but would cost £250 for a full flush through and new filter, now that seems pretty expensive to me, especially when they're usually cheaper than the main dealer.
How much should I be expecting to pay, I seem to recall £140 was mentioned? 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #51767 24th Feb 2011 7:02pm
Did they say whether they flush the old oil out or just drain the sump?
Post #51768 24th Feb 2011 7:08pm
M44K TS
I said a gearbox flush. I had a bad experience on my old 850 T5 Volvo when the oil was just drained from the diff, the ATF was like water and I lost drive a few times, ended flushing it through so I want a full flush done on the RR as I don't want to cut corners. 2006 Mercedes CLS
Post #51771 24th Feb 2011 7:16pm
Problem is there are very few mechanics who will go to the bother of completely flushing. The norm is drain, remove sump, change filter, replace sump, fill, run, drain refill and if you are really lucky but I have only known it to be done once a third drain and refill.
Post #51772 24th Feb 2011 7:22pm
M44K TS
Yeah I thought it would be a pretty involved job to do. The volvo was easy, the ATF cooler was part of the rad, simply remove a metal clip, pull the top hose out, put on a length of clear hose and start the car in neutral, pump about 2 litres out, top up, and repeat until nice a clean. Shame the RR isn't as simple. Big Cry 2006 Mercedes CLS
Post #51777 24th Feb 2011 7:49pm
Dolphinboy
Dan_1984_UK had his done recently. Not sure if it was a full flush or not but was around £160 IIRC
Post #51811 24th Feb 2011 11:17pm
elpeede
Mine £140 flushed - Auto specialist... didn't figging help mind.. though I think the writing was on the wall already. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #51816 24th Feb 2011 11:38pm
