Home > Technical (L405) > L405 trickle charger 12v socket
Willskene
United Kingdom 2017 Range Rover Autobiography SDV8 Firenze Red
I have a Porsche 911 (991) trickle charger which plugs directly into the 12v cigarette lighter socket. Can I use this to charge my 2017 L405 4.4 Autobiography, which is used very little?
Any advice would be appreciated.
Post #488480 9th Sep 2018 9:57am
Montys 4x4
United Kingdom 2017 Range Rover Autobiography TDV6 Carpathian Grey
I had to cut the cigarette lighter plug off my Porsche charger for the Macan which switches off all sockets after 5 minutes and fitted crocodile clips so when long term parking up the range rover I just lifted the bonnet and connected to the jump start points charger did its job. For my older Range Rovers L322 I just had a caravan connector and connected the charger through the towing point connector.
Paul Journey started in a LR2B at 16 and has incl. just about every Land Rover, Disco, RRS and Range Rover Vehicle owned or driven, I even worked for the company when it was owned by BAe - It must be a madness!!! because to add to my 4.4 TDV8 Westminister In Baltic Blue I bought a second L322 as a commuter bus, TD6 2004 Vogue in Oslo Blue with cream leather now both gone replaced with what could turn out to be my biggest mistake. Carpathian Grey ivory interior 3.0 tdv6 Autobiog. 2017
Post #488581 10th Sep 2018 11:57am
charlie croker mk2
get this , connect to the terminals under the bonnet . Works well and is powerful enough to cope but also has a built in program to protect your battery from over charging and it is also temperature compensated .
https://www.ebay.co.uk/itm/New-CTEK-MXS-5-...SwgMBberyX
Post #488721 11th Sep 2018 10:56pm
