Home > Technical (L322) > 2007 new key programming with iid tool
dingg1
has anyone ever managed to achieve this?
been doing my nut in the last two weeks trying to get a result that works
be handy to know if this is achievable or not , seems the 2007/8/9 cars are a breed apart and quite difficult to sort (I think I've proven that) Confused
Post #488303 7th Sep 2018 5:43pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
I need a spare key so I am following your post . I am sure someone said duckworths do a key tied to your vin number mines a late 2006 with the key in the dash so I presume the same as yours and again not sure if you e Mail GAP I think there's something there . Where did you get the key from and when your successful how do you do it Thumbs Up
Post #488305 7th Sep 2018 5:50pm
ptaroni
I programmed mine with my iidtool! Make sure you do it with all the keys as it deleted one when i just programmed the new one if that makes sense! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #488308 7th Sep 2018 6:03pm
dingg1
pataroni
when you say programmed it do you mean a virgin new key , that you coded to the car?
if so do you have a link to the key you purchased ??
thanks
ps I have tried two keys from china that were supposedly for the 2007 , I have chatted to a guy in SA who has managed to code about a dozen cars but has never been able to get a result on a 2007/8/9
pps henda if your key is in the dash you may have the same security measures as the 2007 , do you have touchscreen satnav?
Post #488310 7th Sep 2018 6:18pm
ptaroni
I had 3 with my car, only one worked the immobiliser and remote locking, when i got my iidtool i programmed one! The other two i have today replaced the batteries and cases so will be programming the last unprogrammed one tonight! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #488311 7th Sep 2018 6:25pm
dingg1
thanks
looking for a non dealer supplied key is the holy grail though Smile
Post #488313 7th Sep 2018 6:39pm
clivehandforth
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
Has anyone got any updates on this?
I've got the same issue and also ready to give in! 2 x different ebay keys and a genuine L322 "used" key from a different vehicle and no joy - pcf9741 id46 transponder version is the one that will apparently work.
When programming with the IID, i just get an E7 failed message when inserting and trying to program the 2nd key.
I've emailed GAP for assistance but given the source of my keys.... interestingly, Patrick at GAP also said that the IID can't program genuine but previously programmed keys on the L322.
Can anyone give me anything to go on Bow down
Post #489117 17th Sep 2018 5:23pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
the gap tool for keys is poor, even if you got a dealer supplied key IID tool struggles with L322 2006-2009
I am able to supply any land rover keys please PM me with what you need
Post #490987 4th Oct 2018 8:39pm
supershuttle
 Geoff
Post #491002 4th Oct 2018 11:11pm
