Home > Technical (L322) > TDV8 2010 Top Rad Hose 4 Way Coupling - Please Help Identify |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2315 |
I tapped a 1/8 NPT thread then fitted a 1/8" NPT to 3/8" barb and fitted a 90 deg 3/8" to 3/8" barb at the other end as that fitting also easily breaks, to use 3/8" hose. When I recently replaced all the coolant hoses I retained my modified coupling, hose and the 90 deg at the other end rather than fit fragile originals. |
3rd Mar 2024 8:56pm |
Mfcetin Member Since: 26 Jun 2023 Location: Nuremberg Posts: 46 |
I broke another connection on that brittle pipe. Any ideas how to fix it?
9th May 2024 4:19pm |
I had a closer look and its a connection element between two pipes. Some sort of stent.
9th May 2024 4:26pm |
That stent is broken. Unfortunately you cannot buy only this small part, comes with bunch of other hoses. If anyone needs here is the part number, LR022690
9th May 2024 4:43pm |
More research on this forum showed me that this connector is actually a fuel line quick connector, see discussion here
12th May 2024 2:55pm |
just to confirm that the correct size is this one
15th May 2024 11:31am |
