Home > Maintenance & Mods (L322) > 4.4 TDV8 Rotary gear selector back date to shift lever.
Page 2 of 3 <123>
mjdronfield
When does it go into Park automatically? Mine warns it’s not in P, so I put it in P and get out.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #488529 9th Sep 2018 7:38pm
GGDR
Just wait for the magic, take a couple of secs...
. Cheers, Greg
Post #488531 9th Sep 2018 7:41pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Same as on the D4's just push the starter button, the engine will switch off and 'bong' that the gearbox isn't in P and then it will turn to P and lower itself down Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #488537 9th Sep 2018 8:37pm
A1GSS
Got the rotary thing in my Ewok I hate it. Woefully awful piece of design, slow, unintuitive, you have to look at the thing to use it. How crap is that. The fact that it rises majestically out of the console pales rapidly beside the accidental neutrals and parks. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #488544 9th Sep 2018 9:49pm
GraemeS
I've too often partly or fully exited the vehicle with the selector in reverse when diving out to close a gate behind me because the notch before Park makes me think the selector is indeed in Park. I try to listen for the beep from selecting reverse but sometimes don't hear it, either at all or I'm already outside the vehicle before the beep registers. I have occasionally returned to the vehicle to find it in reverse, a chilling find considering that I've been behind the vehicle with my back to it.
Post #488545 9th Sep 2018 10:04pm
A1GSS
Wow. Not had that. But will try it tomorrow to see if it's a thing. Graham
____
Post #488546 9th Sep 2018 10:29pm
`if you put the parking brake on you can leave the vehicle in any gear you like "accidentally of course" I certainly wouldn't exit leaving the vehicle without applying the parking brake... That could be REALLY dangerous Shocked
Post #488547 9th Sep 2018 11:59pm
Simon123
Wales 2010 Range Rover Autobiography TDV8 Santorini Black
For,my 2 pennies,worth, am used to the 8 speed,rotary and 6'speed with a stick ( will refrain from using knob as could get me in trouble!!). The 8 speed rotary with paddle shifts is way better ie economy and smoothness, but the one thing I like about the stick is its advantage in overtaking, without looking you can just knock the stick over for sport mode as quick as a flash. But with rotary you do tend to look down which means you're taking your eyes off the road for a split second.
Post #488553 10th Sep 2018 8:03am
the tdv8 4.4 with rotary in auto mode is more than capable to make overtaking maneuvers without using the sport mode and paddles..
Post #488554 10th Sep 2018 8:07am
AJGalaxy2012
Why do you have to look down? Feel for the dial (its where it was last time you used it), one click clockwise, job done BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #488555 10th Sep 2018 8:08am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
One click - and the selection you have made appears on the TFT display - which, unless you have tunnel vision, is in your eyeline and can be seen/noticed without looking away from the road.
Post #488557 10th Sep 2018 8:56am
A1GSS
If you remember. to go clockwide If you go anticlock you get neutral which with a bootful of gas is not a good thing. Graham
____
Post #488582 10th Sep 2018 12:23pm
AJGalaxy2012
To be honest, if you cant remember the positions on the dial, you wouldn't remember them on the gear lever either. BMW i3 Electric Car
Post #488597 10th Sep 2018 3:28pm
Ive had four cars with a rotary dial, i drive quite quickly from time to time and have never once used S mode!
Maybe its my mechanically sympathetic mind?...
Post #488602 10th Sep 2018 3:55pm
Or the type of road.....
At certain speeds, S gives a much smoother pick up off roundabouts IMHO because you’re in the right gear with no need to kick down.
Post #488609 10th Sep 2018 5:47pm
Page 2 of 3 <123>
