Home > Maintenance & Mods (L322) > 4.4 TDV8 Rotary gear selector back date to shift lever. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
When does it go into Park automatically? Mine warns it’s not in P, so I put it in P and get out.... 2011 Range Rover Vogue SE 4.4 TDV8
9th Sep 2018 7:38pm |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 |
Same as on the D4's just push the starter button, the engine will switch off and 'bong' that the gearbox isn't in P and then it will turn to P and lower itself down Cheers Ian
9th Sep 2018 8:37pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Got the rotary thing in my Ewok I hate it. Woefully awful piece of design, slow, unintuitive, you have to look at the thing to use it. How crap is that. The fact that it rises majestically out of the console pales rapidly beside the accidental neutrals and parks. Graham
9th Sep 2018 9:49pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
I've too often partly or fully exited the vehicle with the selector in reverse when diving out to close a gate behind me because the notch before Park makes me think the selector is indeed in Park. I try to listen for the beep from selecting reverse but sometimes don't hear it, either at all or I'm already outside the vehicle before the beep registers. I have occasionally returned to the vehicle to find it in reverse, a chilling find considering that I've been behind the vehicle with my back to it. |
9th Sep 2018 10:04pm |
Wow. Not had that. But will try it tomorrow to see if it's a thing. Graham
9th Sep 2018 10:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
`if you put the parking brake on you can leave the vehicle in any gear you like "accidentally of course" I certainly wouldn't exit leaving the vehicle without applying the parking brake... That could be REALLY dangerous |
9th Sep 2018 11:59pm |
Simon123 Member Since: 02 Jan 2018 Location: Pembrokeshire Posts: 32 |
For,my 2 pennies,worth, am used to the 8 speed,rotary and 6'speed with a stick ( will refrain from using knob as could get me in trouble!!). The 8 speed rotary with paddle shifts is way better ie economy and smoothness, but the one thing I like about the stick is its advantage in overtaking, without looking you can just knock the stick over for sport mode as quick as a flash. But with rotary you do tend to look down which means you're taking your eyes off the road for a split second. |
10th Sep 2018 8:03am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
the tdv8 4.4 with rotary in auto mode is more than capable to make overtaking maneuvers without using the sport mode and paddles.. |
10th Sep 2018 8:07am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Why do you have to look down? Feel for the dial (its where it was last time you used it), one click clockwise, job done BMW i3 Electric Car
10th Sep 2018 8:08am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
One click - and the selection you have made appears on the TFT display - which, unless you have tunnel vision, is in your eyeline and can be seen/noticed without looking away from the road. |
10th Sep 2018 8:56am |
If you remember. to go clockwide If you go anticlock you get neutral which with a bootful of gas is not a good thing. Graham ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
10th Sep 2018 12:23pm |
To be honest, if you cant remember the positions on the dial, you wouldn't remember them on the gear lever either. BMW i3 Electric Car
10th Sep 2018 3:28pm |
Ive had four cars with a rotary dial, i drive quite quickly from time to time and have never once used S mode!
10th Sep 2018 3:55pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7945 |
Or the type of road.....
10th Sep 2018 5:47pm |
