![]() | Home > Maintenance & Mods (L322) > Replace Suspension Arm Bushes - What Do You Think? |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Rubber deteriorates with age unfortunately. It's a bit like when your tyres start to crack but there's loads of tread left. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2652 ![]() ![]() |
Mine's rear suspension ball/Rose joints have started creaking at about the same distance - metal on metal creaking due to lack of lubricant. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1559 ![]() ![]() |
Graeme, with the right tools, the rears are very easy to replace. I hired the tools from a bloke on the AULRO forum. Ron B. VK2OTC
Thanks Ron, however my son's tool kit is on hand. I had gained some breathing space by injecting oil though the rubber caps a while ago but noticed the squeak returning yesterday so will start replacing the joints soon. |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Fair point. But it feels like they've worn too early - ie aren't fit for purpose. What do I put here then? |
^^ which one are you referring to? The bushes on the outer ends of the control arms are not rubber, they are rose joints.
The nylon/plastic inserts stop the end play but the load is metal to metal. |
Ahh, thanks Graeme. Ron B. VK2OTC
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Get the parts from site sponsor Advanced Factors and don't forget discount code. See their section... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
I just recently had to replace my rear offside top and bottom rose joints. The car is 11 years old with 80k miles and they looked pretty original to me.
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 ![]() ![]() ![]() |
Wheres the discount code? 2011 RR Autobiography 4.4 TDV8 |
http://www.fullfatrr.com/forum/post485637.html#485637 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
So consensus is the bushes giving up now is wear and tear - thank you.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
well I am about to fit a new bottom rear rose joint and the part is only £20 so someones trying to make an awful lot of money . . . . . . . |
