Home > Maintenance & Mods (L322) > Replace Suspension Arm Bushes - What Do You Think?
Page 1 of 3 123>
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
My FF's just been in at the main-stealer for some warranty work.
They've said the creaking noise I hear is my front and rear suspension bushes - they need replacing.
The stealer says this is wear & tear so not covered by my warranty.
My car will be 7 in November and has done just under 59k miles.
Should I push the point that this is too soon for wear & tear, or accept it and shell out?
What do you think? What do I put here then?
Post #487572 30th Aug 2018 2:10pm
Paul thornton
Rubber deteriorates with age unfortunately. It's a bit like when your tyres start to crack but there's loads of tread left.
Post #487583 30th Aug 2018 5:52pm
GraemeS
Mine's rear suspension ball/Rose joints have started creaking at about the same distance - metal on metal creaking due to lack of lubricant.
Post #487595 30th Aug 2018 8:52pm
p38arover
Australia
Graeme, with the right tools, the rears are very easy to replace. I hired the tools from a bloke on the AULRO forum. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #487599 30th Aug 2018 10:12pm
GraemeS
Thanks Ron, however my son's tool kit is on hand. I had gained some breathing space by injecting oil though the rubber caps a while ago but noticed the squeak returning yesterday so will start replacing the joints soon.
Post #487601 31st Aug 2018 12:39am
GAC23
Fair point. But it feels like they've worn too early - ie aren't fit for purpose. What do I put here then?
Post #487619 31st Aug 2018 9:29am
p38arover
Australia
^^ which one are you referring to? The bushes on the outer ends of the control arms are not rubber, they are rose joints.
I thought they were metal on metal but it seems they have plastic/nylon(?) strips as a bearing surface. Here's one of mine with the rubber boots removed and degreased - you can see the strip protruding out of the bush.
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #487793 2nd Sep 2018 4:09am
GraemeS
The nylon/plastic inserts stop the end play but the load is metal to metal.
Post #487796 2nd Sep 2018 6:17am
p38arover
Australia
Ahh, thanks Graeme. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #487797 2nd Sep 2018 6:22am
DrRob
Get the parts from site sponsor Advanced Factors and don't forget discount code. See their section... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #487805 2nd Sep 2018 7:20am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I just recently had to replace my rear offside top and bottom rose joints. The car is 11 years old with 80k miles and they looked pretty original to me.
I would say that it's quite possible at 7 years to have to replace them. I guess it just depends on how the car has been used.
Post #487816 2nd Sep 2018 8:47am
dirtymonkey38
Wheres the discount code? 2011 RR Autobiography 4.4 TDV8
Post #487818 2nd Sep 2018 9:17am
DrRob
http://www.fullfatrr.com/forum/post485637.html#485637 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #487891 3rd Sep 2018 11:32am
GAC23
So consensus is the bushes giving up now is wear and tear - thank you.
I've asked the main stealer and a respected independent for a quote.
How on earth can replacing a few bits of rubber cost £1,600!!!
Because they want to replace the suspension arms too. Surely I don't have to do this? What do I put here then?
Post #488058 5th Sep 2018 9:50am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
well I am about to fit a new bottom rear rose joint and the part is only £20 so someones trying to make an awful lot of money . . . . . . .
Post #488103 5th Sep 2018 8:48pm
Page 1 of 3 123>
