Home > Technical (L405) > L405 centre console side fascia removal
mbdj
Does anyone know how to remove the side trim panel it’s aluminium and scratched badly?
Post #487521 30th Aug 2018 8:58am
Pull it towards you when your sat in the drivers seat... Its on 3 or 4 slide clips sir Thumbs Up
Post #487531 30th Aug 2018 9:24am
mbdj
Perfect thanks Thumbs Up
Post #487533 30th Aug 2018 9:33am
seanjmcgrath
Ireland 2017 Range Rover Vogue TDV6 Carpathian Grey
Did this simple procedure work?? do you not have to remove the trim surrounding the centre screen before pulling the aluminium strips forward ??
Post #518862 18th Jun 2019 7:15am
RRVSE-2
United Kingdom 2017 Range Rover Vogue SE SDV8 Balmoral Blue
It works - just needs a good pull. You might have to search for the clips though, mine stuck and had to use tweezers and a small telescopic magnet to retrieve them! Keith
Main car : FFRR L405 Vogue SE SDV8 Balmoral Blue
Main M/C : Ducati Multistrada 1200S
Other
Suzuki Jimny
Past Cars
Ford Fiesta Titanium
D4 Nara Bronze HSE
D3 Teal S
Post #518869 18th Jun 2019 8:11am
seanjmcgrath
Thanks Keith, do I need to remove the trim that surrounds the centre screen.... or can I just pull the strips forward as you describe ???
Post #518871 18th Jun 2019 8:18am
RRVSE-2
Just slide it towards you as straight as you can. Keith
Other
Suzuki Jimny
Past Cars
D4 Nara Bronze HSE
D3 Teal S
Post #518872 18th Jun 2019 8:31am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Thumbs Up Thumbs Up
Post #518926 18th Jun 2019 5:01pm
