![]() | Home > Technical (L405) > L405 centre console side fascia removal |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Pull it towards you when your sat in the drivers seat... Its on 3 or 4 slide clips sir |
mbdj Member Since: 14 Jul 2010 Location: scotland Posts: 98 ![]() ![]() ![]() |
Perfect thanks |
seanjmcgrath Member Since: 18 Jun 2019 Location: Meath Posts: 2 ![]() ![]() ![]() |
Did this simple procedure work?? do you not have to remove the trim surrounding the centre screen before pulling the aluminium strips forward ?? |
RRVSE-2 Member Since: 06 Jun 2015 Location: Kent Posts: 41 ![]() ![]() ![]() |
It works - just needs a good pull. You might have to search for the clips though, mine stuck and had to use tweezers and a small telescopic magnet to retrieve them! Keith
Thanks Keith, do I need to remove the trim that surrounds the centre screen.... or can I just pull the strips forward as you describe ??? |
Just slide it towards you as straight as you can. Keith
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1435 ![]() ![]() ![]() |
