Home > Technical (L322) > Can a 07-12 S/C fit in a 1.83m car park?
JC1098
Canada
Yes, another height thread.
Currently looking at 07-12 S/C, I can't find a definitive answer as to whether it'll fit in a 1.83m car park or not.
I've found all sorts of info, and I'm cutting it so close that it's hard to be sure.
So I've found this in a previous thread, which would be just enough in access height but it might be for 03-05 years.
B Overall height
- Access height 1 820 mm 71.7 in
- Motorway height 1 840 mm 72.4 in
- Standard height 1 865 mm 73.4 in
- Off-road height 1 913 mm 75.3 in
http://www.fullfatrr.com/forum/post302284.html
stan wrote:
from the owners manual,
But on the wiki, height is 1.90m or 1.87 depending on year, minus 40mm for access height still isn't enough.
On top of that, I can't figure out if those numbers are with or with the GPS antenna.
I could bring a measuring tape when I go try them out, but the accuracy of that isn't the best. Nor do I know how accurate the car park's limit is, but that one's easier to measure.
Secondary question, can I go all the way down to the bump stops? Either a hidden lower-than-access mode, or some electronic fiddling (IID Tool? EAS Control? GraemeS -not sure I have the right user- sells adjustment chip or tool?)
If yes, what's the height then?
Of note, I do want full height for driving around on and off road. Not keen on a permanent lowering.
Post #487274 27th Aug 2018 2:58pm
In access height, it fits under the 1.85 barrier at the Eurotunnel with not much to spare
1.83 might be possible but you'd really need to try it & measure your own car to be sure.
Depending on which antenna you have, that's possibly not the highest point as the roof is slightly lower at the rear (or is that just the L405 Confused )
Is this for long term use or just a one time thing ? There's the old let some air out of the tyres if it's just one time......
Post #487277 27th Aug 2018 3:15pm
JC1098
Canada
Not a one time thing I'm afraid, it's the work car park.
I'm in the same boat, I feel as though it might be possible ... could go either way!
I did just find this other link, in terms of electronics fidgeting : https://www.landroverpassion.com/en/produc...2010-2012/
Sent them an email inquiring about the extra low mode.
edit - they just got back to me
Quote:
The Extra Low program lower the vehicle approx. 9cm from the Standard height, 4cm more than you can reach in Access mode.
If the std height is indeed 1.90m, that gets me a whole 2cm to spare. Laughing
I will report back once I have everything in hand.
Post #487284 27th Aug 2018 3:55pm
Even if we know we can get under the barrier, we still duck inside the car, and for every concrete beam in multi-storey levels Laughing
Hope you can fit it in (ooer missus!) .
Post #487306 27th Aug 2018 6:18pm
ilard
I would just invite one or more forum members to meet you in that car park, set up a time lapse camera, and then see what happens.
Post #487318 27th Aug 2018 8:06pm
Not too many members in Canada Whistle
Post #487323 27th Aug 2018 8:44pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
What about investing in a Llams kit for your beast.
I'm sure it would provide enough low clearance for your beast to fit under the height of the roof.
Its just a plug and play in your model.
Contact GrahamS in Australia for more details.
cheers
Post #487325 27th Aug 2018 10:30pm
JC1098
Canada
Ah yes! That's the one I'd heard about. Thanks for the link, that's bookmarked. And sending him a PM. Smile
Not many members in Canada, even fewer willing to throw their truck under a garage door that just looks too low! There is a 2010/2 FFRR HSE in the neighborhood, but I have no idea who the owner is and am not about to start measuring it out on the street.
At this point I'm reasonably confident it will fit (with the Llams or equivalent controller). Time to go on a hunt for clean FFRR.
Post #487359 28th Aug 2018 2:37pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Could you dig a bit of the floor out? 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #487361 28th Aug 2018 3:20pm
Rosco
Change jobs is the easiest option Rolling with laughter
Post #487362 28th Aug 2018 3:31pm
Make up a frame somewhere and do a detour on your test drive Thumbs Up
Post #487380 28th Aug 2018 6:49pm
holidaychicken
If you go fast enough it will go under
Post #487402 28th Aug 2018 9:28pm
Paul thornton
The easiest (most sensible) answer would to buy an IID tool and lower the access height then drop it to access before approaching the barrier.
Post #487412 29th Aug 2018 7:51am
Can the IID tool set just the access height ?
I’ve never tried, but thought I’d read that it lowers all heights by the same amount.
Post #487418 29th Aug 2018 9:47am
from the 2006 years you correct Alistair, anyway who would want to use the iidtool to lower day in day out....
Post #487422 29th Aug 2018 10:43am
