Home > In Car Electronics (L322) > the wife said it was to small......
Page 2 of 4 <1234>
verydisco
Most US states do enforce this nowadays also. Ask me how I know Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #485604 10th Aug 2018 9:06am
Baltic Blue
Stan,
Are you happy with the Nav unit pictured?
I am looking to buy one for my holiday trip .
I assume it is the £40/45 unit on EBay?
Post #485607 10th Aug 2018 9:13am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Thanks nino & Joe, that looks good Thumbs Up Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #485618 10th Aug 2018 9:49am
nino_nino
That is the one I have, Joe. where I live this is legal Smile
Post #485619 10th Aug 2018 9:51am
nino_nino
Joe, John - don't forget to ease edgis on it. the way they come edges are very sharp and can scare the leather,
Nino,
Post #485620 10th Aug 2018 10:04am
@mike, its an xgody make which is one of the better ones....only done a short trip this morning using it and it performs as good as the 5 inch one i replaced .. ... - .- -.
Post #485621 10th Aug 2018 10:30am
Baltic Blue
Following Stan’s upgrade to 7”,
I went for a central position, where it doesn’t block the windscreen.
Stan, between our two trips, we will have found our way around half of the EU.
Post #486261 16th Aug 2018 9:30am
Laughing so true Mike....
i was going to mount mine there ,even made a removable bracket for it but the wife didnt like it...
how is yours mounted?... ... - .- -.
Post #486266 16th Aug 2018 9:44am
Baltic Blue
Very simple bracket.
Backplate taped to L bracket which simply pushes in to gap between display unit and dash top.
It’s very secure, but removes in 2 seconds when not needed.
Post #486267 16th Aug 2018 9:56am
thats very clever Mike..does it 'wobble' at all and i gather theres no obstructions when you slide it in.....
mine was a bit more complicated as i used the top vent and clipped the mount on top and bottom of it.. ... - .- -.
Post #486268 16th Aug 2018 10:20am
Baltic Blue
I have only done one trip , but no wobble. Because the back of the Nav unit pushes up against the dash top to keep it steady.
Push a credit card in the gap and you will see it goes in with no obstructions.
Pity I didn’t have any black tape, otherwise I would probably leave it in situ for the complete holiday, just removing the Nav unit when I park up.
Post #486270 16th Aug 2018 10:33am
thanks mike..
i can see the screen very well where i have mine at the moment but its hard to see from the passenger seat which could be a blessing in disguise Mr. Green ...
i might re-position it to where you have yours and see if the wife can cope with it there... ... - .- -.
Post #486272 16th Aug 2018 11:42am
thanks mike..
when do you go btw....... ... - .- -.
Post #486273 16th Aug 2018 11:42am
here's a thought mike, if you turn your bracket upside down and turn the sat nav holder 180 degrees , the nav will be in front of the FF's [useless sat nav] screen .. ... - .- -.
Post #486276 16th Aug 2018 11:51am
Baltic Blue
That was Mk 1 Stan, Rolling with laughter Rolling with laughter , but I opted for keeping the screen in view.
Probably will finish up with Mk 5 Rolling with laughter Rolling with laughter
Mike.
It’s raining so working on Mk 3, a hinged version of Mk 1, for when you need to view the screen.
Mike.
PS
We sail Plymouth to Santander Sunday 16th September. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #486277 16th Aug 2018 12:34pm
Page 2 of 4 <1234>
