Home > In Car Electronics (L322) > Central locking (Or not!)
DarkWheel
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
Hi all - hope someone can tell me this is a quick, easy fix - but I'm not holding my breath!
The central locking on my 2004 Autobiography 4.4V8 is screwed up.
Driver's door - Doesn't respond to the remote - will lock and unlock with the key.
Front passenger door - Operates with the remote and key perfectly
Tailgate - Locks and unlocks with the remote and key as it should.
N/S rear will not unlock with the remote (or with the driver's key) but will lock with both
O/S rear will not unlock with the remote (or with the driver's key) but will lock with both.
If I have to replace the driver's locking mechanism - does it have to be re-coded to the remote, or is that elsewhere in the car?
Thanks
Pete
Post #485305 6th Aug 2018 1:15pm
DarkWheel
Just a blatant bump to see if anyone can respond to the problem above?
Post #493224 22nd Oct 2018 10:12am
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
Check for faults on iid if u can. Have the same model and year and my fault was heavy steering and rear pass door lock operating intermittently until it stopped all together. wouldn’t work on the central button nor key fob.
BCU was the issue. Well documented here. Sits under the pass seat and can be changed by yourself in under an hour (there is an excellent guide on here.)
New ones are c. £200 so make sure it is definitely that at fault Thumbs Up
Post #493264 22nd Oct 2018 3:09pm
DarkWheel
Thanks for the info - I'll check connections first!!
Need to get myself an IID tool - stop me from bothering everyone on here
Post #493265 22nd Oct 2018 3:14pm
davidmg
2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Try re-syncing the keys with the vehicle, to see if that make any difference
Post #493266 22nd Oct 2018 3:25pm
DarkWheel
Thanks David - I would've thought that if the key was out of sync - none of the locks would operate?
I'll still check though - what's the point in asking for advice on here if you're not going to follow it?
Cheers
Post #493267 22nd Oct 2018 3:29pm
