Home > Technical (L322) > transfer box clicking noise
petebowling
United Kingdom 2003 Range Rover Vogue SE Td6 Java Black
Hi all
After some advice when I brake I am getting a click from underneath the left side of the my rr first I thought brakes but have found it to be on the front prop shaft at the transfer box end, I have taken the prop/tube off there is no wear on the diff coupling or tube splines the rubber doughnut seems ok and the prop tube coupling that slots into centre everything seems ok but would like to replace but cannot find one anywhere, the flange that is on the transfer box when in park will move left and right about half a centromere and this is what is clicking I think?
Has anyone had this problem before its on my l322 2003 3.0td6 auto, is this a major problem as I have only owned mt RR for about 3 months.
Hope someone can help.
Many thanks
Petebowling.
Post #485275 6th Aug 2018 6:32am
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Had the same click under braking found it to be a control arm bolt not tight enough after replacing arm also have a look at caliper bolts as they can sheer .Up on ramp big bar and a bit of grunt on all bolts .Good luck
Post #485284 6th Aug 2018 9:39am
petebowling
Transfer Box Clicking Noise
Hi riK
Thanks for this I will take a look as I have changed both front sides about a month ago, but the noise sounded more middle of the car noise travels I suppose.
Ill find a big bar.
Many thanks.[/b]
Post #485286 6th Aug 2018 10:10am
rik
Check the drop links aswel they can be a suspect if it's happening when braking don't see how it could be transfer box
Post #485310 6th Aug 2018 2:28pm
petebowling
Transfer box clicking noise
Hi riK
Have checked all nuts bolts had all brakes apart re torqued etc, why do you think it can't be transfer box as it happens when braking? I'm not sure how the transfer/ prop etc work.
Thanks
Petebowling
Post #485325 6th Aug 2018 6:01pm
rik
Is it one hard click under braking ?
Post #485326 6th Aug 2018 6:10pm
petebowling
Yes when you first brake its a metal clunk
Post #485328 6th Aug 2018 6:14pm
rik
Still sounds like a loose bolt these bolts have to be realy tight and can be a swine to diagnose as they seem tight I had same noise with mine after fitting aftermarket arm and I thought I had tightened it pretty tight but when I had a bar on nut and spanner wedged on but lying on my back with foot on it and used a lot of grunt it shut it up .Mine sounded like someone hitting bare metal with a hammer when braking and reset itself until next time I braked .Very annoying
Post #485330 6th Aug 2018 6:33pm
Sound location can be deceiving. I was convinced I had a knocking at the rear of the car.
Resolved by fitting FRONT ARB drop links Shocked Thumbs Up .
Post #485333 6th Aug 2018 6:38pm
petebowling
Thanks to you both I am going to take the aftermarket drop links off and change to genuine.but yes riK it's as you said bare metal with a hammer.
I'm also going to change front anti roll bar bushes whilst it's apart. Once prop tube arrives I'll fir everything and try it see what happens.
Thanks for help I'll keep you informed if it cures it.
Post #485336 6th Aug 2018 7:00pm
rik
Good luck 👍
Post #485343 6th Aug 2018 8:37pm
Sannan75
England 2008 Range Rover SE TDV8 Santorini Black
Hmmm, I've read this post because I have a similar clunk but not quite...
I get a soft but distinct clunk sound (similar to the sound you get when you first move off after washing your car and leaving it overnight and the pads un-stick as you pull away). It consistently happens when turning the wheel to the left at slow speed, and the steering passes through halfway to full lock. Doesn't seem to happen in any other position.
Could it be a loose bolt too?
(new RR owner, had my 2008 Vogue for a couple of months now)
Post #486285 16th Aug 2018 1:11pm
rik
Def worth checking bolts .They need to be real tight .Check caliper bolts and drop links . Probably find anti roll bar bushes are ok opposing forces make rattles and bumps hard to track .as in left hand drop link worn knock on right side you can spend a lot on wrong side if you don't find it .Get a few bodies to rock her hard with someone under her and you may find prob
Post #486297 16th Aug 2018 4:53pm
Sannan75
Thank you, appreciate the advice Smile
Post #486299 16th Aug 2018 5:36pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
If you get a clunk when tapping the brakes or when braking suddenly you maybe can feel it thro the steering it's normally a bush off somewhere even new ones fail .
It's all ready been said but get a bar or big screw driver and check for play in the suspension Thumbs Up
Post #486301 16th Aug 2018 6:17pm
