Home > Maintenance & Mods (L405) > My2014 FBH
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
My2014 FBH
Finally got my new to me FFRR today it's a Vogue Se TDV8 and was surprised there was no option on the centre screen for Timed Climate Confused I've had a look at Topix for my car and it lists
FUEL OPERATED HEATER
LESS PARK HEATING
LESS ENGINE BLOCK HEATER
So I take it from that it doesn't have the block heater but does have a FBH so is it able to have Timed Climate enabled like on the Disco's with an IID Tool?
I've searched through various posts and the Wiki section but can't seem to find a definite answer Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #484334 25th Jul 2018 9:54pm
As far as I'm aware the VSE does not have the hardware to allow the remote fob and AB cars were... You can however enable timed climate on a seven day timer on a VSE... Thumbs Up
Post #484342 26th Jul 2018 12:07am
Hairy Dan
Brilliant Craig, need to get my IID tool out then Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #484348 26th Jul 2018 6:47am
Andy B
It is probably one of these you need to configure :-
 SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #484364 26th Jul 2018 10:56am
Hairy Dan
Thanks for that Andy, I'll let you know how I get on Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #484376 26th Jul 2018 12:57pm
Andy B
Cheers Ian, I need to do the same so please let me know! SDV8 AB MY 2019
Post #484377 26th Jul 2018 1:05pm
Hairy Dan
Just been out and tried it, the only thing I could see was Timed climate which I changed from not fitted to fitted but alas that hasn't enabled it
FBH call start is (I think) when you have the receiver fitted for remote use which as Craig has mentioned you can't do. I may try changing Fuel Fired Heater FFH to Fuel Fired Parking Heater FFPH and see if that makes any difference Cheers Ian
Kielder 4x4 Safari
Post #484398 26th Jul 2018 6:35pm
Andy B
Hi Ian, tried FFPH and this brings up the timer menu under ‘Extras’. But also generates an ECU fault Big Cry
Getting the air con re-charged tomorrow, so will stop messing about until after that is sorted! SDV8 AB MY 2019
Post #484404 26th Jul 2018 8:03pm
Hairy Dan
I was just coming back to post that I've got it on the screen but have an ECU fault Laughing I take it you got the same HVAC one?
 Cheers Ian
Kielder 4x4 Safari
Post #484405 26th Jul 2018 8:24pm
Andy B
Yeh, same one Ian Rolling Eyes SDV8 AB MY 2019
Post #484407 26th Jul 2018 8:39pm
Hairy Dan
Well digging this old thread up, it was rather chilly last night so I set the timed climate to come on 20 minutes before I was due to go out this morning. It was 4 degrees this morning and happy to report that despite the HVAC fault still being there it came on and was blowing warm air out of the vents when I went out to it Mr. Green Just wish there was a way to have some sort of remote setup to trigger it. Crying or Very sad Cheers Ian
Kielder 4x4 Safari
Post #489880 24th Sep 2018 9:12pm
Andy B
Hi Ian, glad it worked mate. I'll set mine up this evening Thumbs Up Brass monkeys this morning!
Cheers,
Andy SDV8 AB MY 2019
Post #489924 25th Sep 2018 3:26pm
charlie croker mk2
surely the remote app on your phone will switch the fbh on from anywhere , mines a 2015 and it works perfectly .
Post #489957 25th Sep 2018 8:41pm
Hairy Dan
Is the app part of the Incontrol bits and pieces? If so my car doesn't have Incontrol so can't set it from that Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #490075 26th Sep 2018 9:29pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I have a spare key fob new from the dealer if your interested. Programming is easy, you only need to remove the panel in the boot and unplug the T91 telestart module, then plug it back in while holding the on button on the key fob for 5 seconds and job done your all synced up and ready to go. Key fobs from the dealer are £165 including vat IIRC Thumbs Up
Post #495204 11th Nov 2018 10:01am
