![]() | Home > Maintenance & Mods (L405) > My2014 FBH |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 ![]() ![]() ![]() |
Finally got my new to me FFRR today it's a Vogue Se TDV8 and was surprised there was no option on the centre screen for Timed Climate |
Brilliant Craig, need to get my IID tool out then |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
It is probably one of these you need to configure :-
Thanks for that Andy, I'll let you know how I get on |
Cheers Ian, I need to do the same so please let me know! SDV8 AB MY 2019
Just been out and tried it, the only thing I could see was Timed climate which I changed from not fitted to fitted but alas that hasn't enabled it
Hi Ian, tried FFPH and this brings up the timer menu under ‘Extras’. But also generates an ECU fault |
I was just coming back to post that I've got it on the screen but have an ECU fault |
Yeh, same one Ian |
Well digging this old thread up, it was rather chilly last night so I set the timed climate to come on 20 minutes before I was due to go out this morning. It was 4 degrees this morning and happy to report that despite the HVAC fault still being there it came on and was blowing warm air out of the vents when I went out to it |
Hi Ian, glad it worked mate. I'll set mine up this evening |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
surely the remote app on your phone will switch the fbh on from anywhere , mines a 2015 and it works perfectly . |
Is the app part of the Incontrol bits and pieces? If so my car doesn't have Incontrol so can't set it from that |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
I have a spare key fob new from the dealer if your interested. Programming is easy, you only need to remove the panel in the boot and unplug the T91 telestart module, then plug it back in while holding the on button on the key fob for 5 seconds and job done your all synced up and ready to go. Key fobs from the dealer are £165 including vat IIRC |
