Home > Technical (L322) > hear clunk when coming to first stop after sitting overnight
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I guess this is the proper area to put issue threads, Mod's you can delete other.
So if I leave the Range overnight (this is when I seem to notice it...not sure how many hours are needed) and I get in it to go somewhere I almost always am hearing a clunk now at the first stop or slowing to first full stop. It almost sounds like a suspension clunk...but I can't get it to repeat. It only happens at first stop. For this reason I was/am thinking maybe its the brake pads seating themselves against the rotor...but I'm not so sure. Its an audible clunk not like a tap 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #396847 20th Jul 2016 1:39pm
holidaychicken
If you reverse off your drive and brake then drive forwards and brake it could be pads moving or one of the many suspension arms and bushes that wear. I have a 6 sensor electronic stethoscope I use to try and find such noises but I have a clunk I have been trying to find for 3 years now ...
Post #396929 20th Jul 2016 10:22pm
horse86
good point. I do back out of the drive at every house I'm at and then put it in D and drive off....then at the first stop "clunk". But never again during the drive. It only happens once so it's hard to figure it out with steth....plus it's not going to be able to be applied to a moving vehicle. Maybe I'll try going in reverse then D, and repeat a bunch to see if thats it. I was originally thinking suspension that maybe the suspension levels off or does it's thing while sitting and first stop the suspension is shifting causing it...but the more I thought about it...if it was suspension I should hear it while driving too. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #396976 21st Jul 2016 12:06pm
holidaychicken
Most of the battle is recreating the noise, once you can do that you are half way there, although i can recreate my clunk i still cant find the damn cause !!
There are some rather large bushes in the rear subframe that could move one way in reverse under braking then shift forwards under the first braking, good luck !!
Post #397039 21st Jul 2016 6:32pm
horse86
well if its not bad enough to constantly clunk it must not be too bad right?? haha that's what I'll keep telling myself. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #397124 22nd Jul 2016 12:35pm
holidaychicken
They are pretty well built, i can't think of anything that could drop off but then i cant think why i bought a range rover in the first place either
Post #397160 22nd Jul 2016 3:40pm
petebowling
United Kingdom 2003 Range Rover Vogue SE Td6 Java Black
Brake clunk
Hi all, I have the same clunk noise when I touch the brake for the first time but it's every first time I brake whilst traveling.
When I first brake it clunks then I release if I brake again after no noise.?
Would this be bushes do you think. I had the front wheel off tonight and checked bolts calipers knuckle joints etc nothing loose.
What do you think my veihcle is the l322 td6 vogue 2003
Post #484256 24th Jul 2018 7:19pm
