Home > Technical (L322) > Rubbing noise front right
WeeJ
When I turn left at medium speed I get a rubbing noise. Its a kind of shuch shuch shuch tpye noise but I cant see anything rubbing or loose. `Any ideas?
Post #403950 7th Sep 2016 8:10pm
wheel bearing?
what wheel and tyre combo have you got? There is nothing that can't be fixed with a hammer😜😜
Post #403956 7th Sep 2016 9:02pm
Dolphinboy
Brake shield?
Post #403958 7th Sep 2016 9:16pm
holidaychicken
Either of the above or loose heatshield around front prop?
Post #405298 18th Sep 2016 8:41pm
Big Mac
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
OSF Rubbing Noise
Hi there I have the same issue, recently the cars had new discs and pads and new replacement suspension bags all around (just to rule them out) did you ever get to the bottom of this ?
Cheers
Post #484247 24th Jul 2018 5:35pm
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
I'd expect some noise from the pads and discs as the two new faces bed in. It should go after a few hundred miles of gentle bedding in driving. Don't stamp on the brakes to bed them in faster, you'll only warp the disc and need new ones again.
Post #484280 25th Jul 2018 6:26am
Big Mac
Hi I’ve done around 1200 miles since the disc and pads were replaced, the noise was there before and afterwards. Also the noise doesn’t happen when the cars cold, only after it’s warmed up
Post #484284 25th Jul 2018 7:06am
Paulus1978
My next suspect would be a wheel bearing then. I'm assuming based on what You've said the noise doesnt go away under breaking?
Post #484289 25th Jul 2018 7:33am
Big Mac
Hi there no the noise doesn’t go away under braking and only there on the up take from say 5mph to 30 mph before the engine noise possibly drowns it out (no noise when slowing down), could it be the diff as when the vehicles been stood and cold the noise isn’t there for the first mile or so
Post #484295 25th Jul 2018 9:02am
