![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
If that's the case, then there's something wrong with your cars software. I've never seen that on a JLR or any of the other half-dozen marques I've worked for at diag tech level or above.
I don’t watch dpf regenerations obsessively but was just curious to observe how it worked at one point on my car which may well be faulty or have been interfered with by the GAP IID tool but I’ve not had a DPF warning in >20k miles of ownership. 2012 TDV8 Vogue (L322) |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1310 ![]() ![]() |
Ha Ha I am one of those who does like to monitor Regens ![]() It interest's me how the software works, utilising all the sensor inputs etc, would love to see the flow diagram! and when using my iPhone in a cradle with the sky scanner app, watching it live, it is interesting. I can monitor coolant temp, oil temp, def diff pressure, exhaust temps along the exhaust train also soot % Trigger point etc etc A lot more selectable inputs. And I set an alarm at trigger 2 to let me know an AR has started. Which is useful in preventing interrupted AR (engine stopped) which contribute to extra fuel dilution and reduces service miles. Also I can see if an issue is developing with the dpf - where most people wouldn't know, till they get the dreaded Amber & Red etc Horses for courses ![]() |
@K |
I suppose because it's stuff I see at work, the novelty of seeing live values on a road test has worn - I do prefer to watch the traffic and surrounding countryside out of the car windows though, I don't think I'd like to be watching a phone screen whilst driving....
Yes unlike you ![]() ![]() |
@K |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
The active regen process can be actually seen clearly without any diagnostic tool by just observing instant fuel consumption - it is 4-5 l/100km higher than normal.
glenney Member Since: 04 Jan 2021 Location: East Sussex Posts: 21 ![]() ![]() |
Bloody Helpful post.
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
I can't seem to get my IID tool to force a regen at all.
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 123 ![]() ![]() ![]() |
Hello All,
Did they clean it by removing it from the vehicle and back flushing the ash out? 150g seems not very much TBH. 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
If the amber light went off after a natural regeneration on a run then why have it cleaned? It’s working as it should or am I missing something? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
The first time I went there, in 2019, they cut the exhaust at 2 points based on images I found on this forum (I'm not sure it was in this post).
