Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
If that's the case, then there's something wrong with your cars software. I've never seen that on a JLR or any of the other half-dozen marques I've worked for at diag tech level or above.
7th Jan 2023 9:13pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3187 |
I don’t watch dpf regenerations obsessively but was just curious to observe how it worked at one point on my car which may well be faulty or have been interfered with by the GAP IID tool but I’ve not had a DPF warning in >20k miles of ownership. 2012 TDV8 Vogue (L322) |
8th Jan 2023 8:20am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1194 |
Ha Ha I am one of those who does like to monitor Regens but wouldn't class it as obsessive. It interest's me how the software works, utilising all the sensor inputs etc, would love to see the flow diagram! and when using my iPhone in a cradle with the sky scanner app, watching it live, it is interesting. I can monitor coolant temp, oil temp, def diff pressure, exhaust temps along the exhaust train also soot % Trigger point etc etc A lot more selectable inputs. And I set an alarm at trigger 2 to let me know an AR has started. Which is useful in preventing interrupted AR (engine stopped) which contribute to extra fuel dilution and reduces service miles. Also I can see if an issue is developing with the dpf - where most people wouldn't know, till they get the dreaded Amber & Red etc Horses for courses 2018 SE SDV8 4.4 Byron Blue |
8th Jan 2023 3:49pm |
@K t - have you considered that the regen strategy on your L405 may not be identical to that on the L322 2012 TDV8 Vogue (L322) |
8th Jan 2023 3:57pm |
I suppose because it's stuff I see at work, the novelty of seeing live values on a road test has worn - I do prefer to watch the traffic and surrounding countryside out of the car windows though, I don't think I'd like to be watching a phone screen whilst driving....
8th Jan 2023 5:40pm |
Yes unlike you I have looked at both WSM and their explanation, nowhere does it state the AR will stop if you brake or accelerate 2018 SE SDV8 4.4 Byron Blue |
9th Jan 2023 10:31am |
@K t - 2012 TDV8 Vogue (L322) |
9th Jan 2023 10:34am |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 |
The active regen process can be actually seen clearly without any diagnostic tool by just observing instant fuel consumption - it is 4-5 l/100km higher than normal.
9th Jan 2023 6:16pm |
glenney Member Since: 04 Jan 2021 Location: East Sussex Posts: 21 |
Bloody Helpful post.
26th Feb 2023 1:17pm |
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 |
I can't seem to get my IID tool to force a regen at all.
26th Apr 2023 4:05pm |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 101 |
Hello All,
24th May 2023 5:32pm |
Did they clean it by removing it from the vehicle and back flushing the ash out? 150g seems not very much TBH. 2012 TDV8 Vogue (L322) |
24th May 2023 6:12pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
If the amber light went off after a natural regeneration on a run then why have it cleaned? It’s working as it should or am I missing something? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th May 2023 8:10pm |
The first time I went there, in 2019, they cut the exhaust at 2 points based on images I found on this forum (I'm not sure it was in this post).
24th May 2023 10:04pm |
