Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 |
Greg,
24th Sep 2019 3:19pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Mike not sure if the Nexas is VIN locked. I didn't have to register it, just plugged it in and it worked so I don't think so.
26th Sep 2019 12:59am |
flashgordon Member Since: 23 Sep 2019 Location: Hannover Posts: 76 |
great idea! |
26th Sep 2019 2:00pm |
Bit of an update since my last post, I had a word with the manufacturers about their DA-Dongle DPFDR, very helpful. Advice was to carry on driving, monitor soot and wait for it to got to above 17g and then try to let it do it's own regen.
8th Oct 2019 12:28am |
Greg,
8th Oct 2019 12:56pm |
I was thinking about a splitter Mike.
8th Oct 2019 10:20pm |
Not sure a splitter will work, found quite a lot of chat on other forums with this and others saying the same:
16th Oct 2019 5:45am |
Hello, using the IID tool now for every trip. Have seen first patterns how soot concentration behaves/extends and 2 questions related to this: 1) I see the active regeneration gettting started (mainly on motorways) and soot concentration goes down to somewhere between 3 and 7 -- as it should. Unfortunately when this successful process is finished I already can see the soot concentration number climbing again quite fast. City Traffic (Distance: 5-12 miles per trip / Speed: 25-30 mph / Traffic-light-stops: many) brings soot levle concentraion up to 17-20 g within only 50-75 miles. I assume this is way tooo fast, even under these bad traffic conditions for DPFs and this soot-concentration-behaviour indicates hardware-problems ( sensors / (ash) full DPF /...... ? ) ? 2) Greg wrote regarding voltage of the difference pressure sensor a value between 0,7 - 1,0 seems to be good, and values > 1,0 indicate DPF-is-full (more or less). I measured with the IID tool that the values is always between 0,7 and 1,0 when I drive "normal". When I accelerate stronger (what exact is stronger? I know...), for example to overtake someone, then the value increases up to 1,5 max I would be interested in your values here. Is yours stabile in the 0,7 - 1,0 range all the time, even when you accelerate? thanks for this so helpful DPF-blog by the way Gunnar . |
4th Nov 2019 1:08pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
May be a silly question but does using a decent quality fuel (as opposed to supermarket) have any bearing on DPF blockages ? 2003 Range Rover Vogue TD6 |
4th Nov 2019 2:39pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 |
i wouldnt have thought so Brian..i've always used supermarket fuel and have had only 2 yellow regens in the 3 odd years i owned my 4.4 tdv8... ... - .- -.
4th Nov 2019 2:43pm |
I always use supermarket fuel, but decided to do a 4. month trial using Millers fuel additive which it claims to help DPF soot levels, but after adding two bottles of the stuff at £17/ bottle I can report that it made not one jot of difference in any way,
4th Nov 2019 3:12pm |
flashgordon 1.5 is very high so i think you may need to get yours cleaned.
4th Nov 2019 8:58pm |
Apart from injector issues with a used (unknown history) replacement engine my last vehicle a VW Transporter I have never had injector issues with my diesels - all have passed the 250k mark with no injector or fuel issues, all run on Shell/BP with a dash of 2-T added. About 15 years ago a mate & myself bought new identical MB Vito vans - he always used supermarket fuel fuel & needed new injectors at 30k intervals - mine was still on its original injectors at 250k when I traded it in. To me it says it all & I personally will never run any vehicle that I own on supermarket fuel. Best of luck to anyone who does. 2003 Range Rover Vogue TD6 |
4th Nov 2019 10:08pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
Shell V-Power is repeatedly recommended over Supermarket fuel - multiple reasons and sources over a long period. |
6th Nov 2019 2:34pm |
