Home > Technical (L322) > Range Rover tdv8 egr query
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
Fault — exhaust gas recircultion B control low
Only fault with car is at cold it idles incorrectly until it is reved then goes away
When I plug in logger the value of A is 5.1 and B is 4.71 I have read if the value is under 5 it will log a fault
Both valves open and close when engine under load
I don’t want to spend money on car as it is an 07 with 120000 miles
A mechanic in work said I should try a tin of wynns egr cleaner sprayed in bursts in to the air box
Have you guys any experience in this or could it further damage a tdv8 or is it worth a try
Thanks in advance
Post #483744 18th Jul 2018 8:10pm
kbald
What is the actual fault code? Wynns may work but depends on what the error is. Current 2007 TDV8 Vogue Buckingham Blue
Post #483753 18th Jul 2018 9:44pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
You may regret not spending money on it if the egr valves break up and kill it. Quickest fix, map out the egr's for around £150 or spend another £100 and remap the engine too. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #483763 18th Jul 2018 11:06pm
j_rov
CAUTION: I had that symptom before my EGR disintegrated and destroyed the engine and turbo.
Blank it off if you don’t want to do anything else. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #483765 18th Jul 2018 11:10pm
Benner91
Hi this is the fault code it clears straight away but returns first thing when car is stated
Post #483774 19th Jul 2018 8:06am
j_rov
Is it kicking out smoke while idling badly?
It sounds to me like it’s not closing properly.
I really advise it’s looked at ASAP before it turns into a big problem. __
Land Rover History:
1976 Series 3 2.25
Post #483779 19th Jul 2018 9:27am
Benner91
There is no smoke 💨 just a slight hunting of revs at cold start up
I have purchased the wynns egr cleaner and used it last night first thing I noticed the squeak has stopped when I turn off engine
I’ll keep you updated will start car from cold this evening and see what happens
If fault is still present I will look at getting egr valves blocked out I saw a kit on eBay for 35 pounds
Thanks
Post #483849 20th Jul 2018 8:14am
lewis93
Mine is chucking out P0489-00 (2C) Exhaust gas recirculation control - circuit low.
Going to blank the EGRs and get them mapped out which should hopefully fix it.
£1250 for replacement EGRs inc labour!!
Post #483925 20th Jul 2018 7:20pm
Grofus
I can recommend Quantum tuning. They have agents all over so should be one reasonably close to you. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #483938 20th Jul 2018 9:00pm
kbald
Re blocking them out you will need to have them mapped out before you fit that ebay kit or it will throw up the fault light Current 2007 TDV8 Vogue Buckingham Blue
Post #483961 21st Jul 2018 10:05am
