![]() | Home > Technical (L322) > Range Rover tdv8 egr query |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
What is the actual fault code? Wynns may work but depends on what the error is. Current 2007 TDV8 Vogue Buckingham Blue |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
You may regret not spending money on it if the egr valves break up and kill it. Quickest fix, map out the egr's for around £150 or spend another £100 and remap the engine too. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
CAUTION: I had that symptom before my EGR disintegrated and destroyed the engine and turbo.
Benner91 Member Since: 18 Oct 2015 Location: Belfast Posts: 87 ![]() ![]() ![]() |
Hi this is the fault code it clears straight away but returns first thing when car is stated |
Is it kicking out smoke while idling badly?
There is no smoke 💨 just a slight hunting of revs at cold start up
lewis93 Member Since: 23 May 2017 Location: kent Posts: 28 ![]() ![]() ![]() |
Mine is chucking out P0489-00 (2C) Exhaust gas recirculation control - circuit low.
I can recommend Quantum tuning. They have agents all over so should be one reasonably close to you. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Re blocking them out you will need to have them mapped out before you fit that ebay kit or it will throw up the fault light Current 2007 TDV8 Vogue Buckingham Blue |
