Home > Technical (L322) > Gearbox Temperature checking
rkaad
Looking to check gearbox oil level....is using the IID tool accurate enough or would an infrared digital thermometer be better?
thank you
Richard
Post #483579 16th Jul 2018 3:51pm
Weegie
The iiD is probably more accurate than the infrared. John
GAP iiD BT-Sold
Post #483580 16th Jul 2018 4:27pm
RRPhil
The volumetric expansion coefficient of transmission fluid is around 0.07% per °C, so if you’re 10°C out on the temperature, it’s only going to make a difference of 65cc.
By far the most significant factor in getting the fluid level correct is to have the engine running while you set the level.
Phil
Post #483610 17th Jul 2018 12:54am
Pawl
Also make sure that the car is on something level.
Our drive slopes, so I had the car on blocks to compensate & initially it wasn't correct. The fluid level was out by about a litre before I corrected the blocks. Shocked Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #483618 17th Jul 2018 8:43am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Mr Edd (ex of Wheeler Dealers) used an infrared digital thermometer when he did the Porsche Boxster Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #483659 17th Jul 2018 5:34pm
