Home > Maintenance & Mods (L322) > The Mysteries of iphone integration/docking
p-trax
Japan 2011 Range Rover Vogue 4.4 V8 Santorini Black
Another pair of Land Rover riddles for your pontification;
1) the new iphone integration allows bluetooth synchronisation of the phones contacts.
However I see only a small, and random, subset of this (i considered that maybe I had numbers saved on sim/phone - but this is not the case- I also thought that maybe there was a ltd amount of memory assigned to this function. but it is too random in those that it does see).
For example, most of the people i tend to call regularly, do not show when doing an alphabetical search. But, if i browse the recently dialed or received call section, I see these people, by name, and can redial. So essentially not a problem, as long as I do not want to ever search for a number using the touch screen of someone i have not recently interacted with.
anyone else seeing this, or got a solution?
Not surprisingly the dealer is clueless (other than to keep repeating " your phone is 100% compatible according to LR website" ).
2) the centre console/storage/armrest houses the iphone/ipod power/data cable.
this is in the bottom section, and a bit of a pain to get at (not that one would ever want to look at phone whilst driving of course Whistle ).
Below the mat in the next picture is a "punch out" section.
which enables the cable to run through to the top section, that is more accessible and conveniently phone shaped, as in this picture
the dealer assures me that there is no way to mount the phone in the upper section of the arm rest (despite this punch out existing and the fact that i am sure I have seen a picture with a phone mounted here.
In addition i found this picture in the current brochure, which clearly shows the iphone in some kind of holder (not just rolling around in the lower section), again the dealer has no clue how this was achieved (levitating iphone??)
 Gerry
____________________________________________
Arrived>Santorini/Jet FFRR MY11 TDV8
Gone>Stornaway/Ebony MY09 RRS HST TDV8
Gone>Java black/Ebony MY07 RRS HSE TDV6
Post #50289 15th Feb 2011 2:28pm
dan_uk_1984
Have you looked in Microcat to see what cubby box options there are?
D
Post #50296 15th Feb 2011 3:20pm
p-trax
D
Hi Dan, not familiar with microcat, can you link me to it? Gerry
Post #50298 15th Feb 2011 3:38pm
http://www.fullfatrr.com/forum/topic3630.html?highlight=microcat
found by the search function gerry.. Thumbs Up ... - .- -.
Post #50299 15th Feb 2011 3:41pm
p-trax
A quick search turned up this, Ill give it a shot Smile
http://www.fullfatrr.com/forum/topic3630.html?highlight=microcat Gerry
Post #50300 15th Feb 2011 3:41pm
posted the same time mate.. Laughing Thumbs Up ... - .- -.
Post #50301 15th Feb 2011 3:42pm
p-trax
nope doesn't work for me,
after 40 minutes of downloading, and following instruction s in read me file, it just "evaporated".
search hardrive for zip file too, nothing there
bloody bizarre Gerry
Post #50305 15th Feb 2011 4:40pm
its date sensitive as well gerry, you have to change your pc/laptop date to make it work.. ... - .- -.
Post #50307 15th Feb 2011 4:45pm
SteveMFr
Site Sponsor
Hi Gerry,
I assume you meant this?
This is not a dealer option. This is a custom job I did for a friend about a year back in a 2010. It consists of a modified BMW iPhone cradle, a modified RR iPhone/Aux port and the wiring. I could do another, I suppose... I'd have to check on the prices of the bits. Can't remember off the top of my head (I suffer from CRS). Guessing, roughly GBP250. The wiring was all hidden, BTW. Silly to have a squiggly cord running through the middle of the cubby, if you ask me.
Let me know if you're that interested.
Second time I've written that today. I'm going to go into business here. :lol:
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #50332 15th Feb 2011 5:57pm
p-trax
Having successfully wasted a couple of hours of my life trying to get this to work I have given up. Followed instructions, tried everything i could think of, without any joy. Gerry
Post #50365 15th Feb 2011 7:21pm
p-trax
SteveMFr wrote:
Hi Gerry,
Second time I've written that today. I'm going to go into business here. Laughing
That does look like it yes Steve. Thanks for the offer, but I'll pass, i was hoping a simple plug in module existed, to take advantage of the existing holes etc
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Gerry
Post #50366 15th Feb 2011 7:25pm
iceshj
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
SteveMFr wrote:
Hi Gerry,
Hi,
this is just what I am after. Could you send me all the details etc. What does this setup allow you to do. Can you play the music, charge etc etc. Any info you give me would be fantastic. ease to setup/fit??
Kind regards
Dave
Post #60497 15th Apr 2011 6:14pm
ds
United Kingdom 2006 Range Rover Vogue SE Supercharged Buckingham Blue
can anybody help me sort out a pairing issue with my blackberry torch ? the phone keeps connecting and then disconnecting.
i have range rover supercharged 2006 vogue se. the main agents are hopeless. does anybody know if i can get a cradle for this ? it's a shame to have to fit an after-market system just because i have this common issue. any help will be greatly appreciated, thank you ds
Post #63398 11th May 2011 9:46am
having googled this question, it appears that only certain blackberry os will work with the range rover... ... - .- -.
Post #63399 11th May 2011 9:54am
ds
I know, the trouble is, these blackberry's work with the bluetooth side of the system, but then, after a time they suddenly stop working properly.
there is a phone cradle in these range rovers, but there is no update for it. if any fitters out there know how to upgrade this or do a custon job on it, i will be very grateful! thank you ds
Post #63401 11th May 2011 10:07am
