Home > Technical (L322) > TPMS reading too high |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Gents the TPMS on mine is reading the pressures on all tyres including the spare 20 psi higher than actual any way to recalibrate ?? |
23rd Jun 2018 2:04pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
pull the fuse or battery reset... ... - .- -.
23rd Jun 2018 2:24pm |
Thanks Stan will have a go |
23rd Jun 2018 3:41pm |
All sorted switched off with 11d tool then switched back on all good |
23rd Jun 2018 4:21pm |
No can see the readings |
24th Jun 2018 8:56pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
Thanks!
25th Jun 2018 5:37am |
No idea about the D4 but the system on the Fatty is all self learning and once synced you see readings of all 5 wheels if fitted |
25th Jun 2018 7:29am |
Hi do you mean you can actually see the pressure readings?If so can you pass the setting as per your iid tool?My Fattie has TPMS and it alerts when there is a problem but can not see the pressures!Would like to see that if possible.
25th Jun 2018 8:03am |
Can only see the pressure readings when the 11d tool is connected without it connected just an alert or nothing |
25th Jun 2018 8:08am |
Good news of some sort.....at least it reads the pressures and can display it Now to find the correct setting to display it in the dash!! 2012 TDV8 Vogue SE 4.4 |
25th Jun 2018 9:26am |
Where do you see it on iid tool?Best I can see on tool is that the pressure is "OK"!! Thanks 2012 TDV8 Vogue SE 4.4 |
25th Jun 2018 2:45pm |
