Home > Technical (L322) > Multiple computer faults
Victrev
United Kingdom 2007 Range Rover Vogue TDV8 Epsom Green
Hi all, I’m new to this. can anyone help. My rr vogue tdv8 2007 today showed multi faults on trying to start. The AA were unable to diagnose.it started saying suspension fault then parking brake, hdc, air bags, special programs, engine. It then turned over but wouldn’t start. The AA diagnostics seemed to list many other faults - fuel pump, sunroof ..... I then lost power to the dash warning lamps and gauges but not the radio/entertainment console.the central locking works ok and when ignition is switched on the brake lights come on. The AA could find no loose earth connectors.
Any help or ideas would be welcome.
Post #481316 18th Jun 2018 10:19pm
cass
Assuming it’s not the battery/alternator as it does turn over and I would expect the AA man to have checked them, I would start with the ignition switch.
I’ve known a couple fail and it’s not too expensive a place to start.
Post #481325 19th Jun 2018 5:16am
andygts
Remove both battery terminals and touch the leads together for 10 seconds then reconnect, this will reset everything.
When reattaching the battery terminals make sure you get them on firmly before tightening, the posts are tapered so when tighteneing all the clamp wants to do is ride up the post. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #481341 19th Jun 2018 11:00am
I would be inclined to check the battery voltage after overnight just before you try and start the car. It could be that starting the car simply drops the battery voltage to such an extent that the multiple faults show up. If your battery voltage is below 12.6V you may have a problem with your battery or the alternator.
Post #481344 19th Jun 2018 11:58am
Victrev
Thanks for replies. I tried all suggestions but still no good. Have just had it transported to LRR in charlton
Post #481362 19th Jun 2018 3:12pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
How old is the battery. RR's are hard on them and demand a good healthy one. First sign its failing are the symptoms you got. If the ecu cant work out the crank position it wont fire up. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #481393 19th Jun 2018 9:38pm
just a guess but as its an 07 tdv8, I would say alternator has packed up, possibly taken the battery along with it. Common problem on the 3.6, relatively easy fix though. There is nothing that can't be fixed with a hammer😜😜
Post #481419 20th Jun 2018 8:44am
Victrev
Hi all
Just got car back, it was the ignition switch.
If you’re SE London I recommend LRR in charlton
Post #481682 23rd Jun 2018 11:03am
