Home > Technical (L322) > Multiple computer faults |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 732 |
Assuming it’s not the battery/alternator as it does turn over and I would expect the AA man to have checked them, I would start with the ignition switch.
19th Jun 2018 5:16am |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
Remove both battery terminals and touch the leads together for 10 seconds then reconnect, this will reset everything.
19th Jun 2018 11:00am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I would be inclined to check the battery voltage after overnight just before you try and start the car. It could be that starting the car simply drops the battery voltage to such an extent that the multiple faults show up. If your battery voltage is below 12.6V you may have a problem with your battery or the alternator. |
19th Jun 2018 11:58am |
Victrev Member Since: 18 Jun 2018 Location: London Posts: 3 |
Thanks for replies. I tried all suggestions but still no good. Have just had it transported to LRR in charlton |
19th Jun 2018 3:12pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
How old is the battery. RR's are hard on them and demand a good healthy one. First sign its failing are the symptoms you got. If the ecu cant work out the crank position it wont fire up. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
19th Jun 2018 9:38pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
just a guess but as its an 07 tdv8, I would say alternator has packed up, possibly taken the battery along with it. Common problem on the 3.6, relatively easy fix though. There is nothing that can't be fixed with a hammer😜😜
20th Jun 2018 8:44am |
Hi all
23rd Jun 2018 11:03am |
