![]() | Home > Technical (L322) > Is towbar bought for a 2004 the same fitting as a 2007 car |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35593 ![]() ![]() |
the exhaust hangers will be in a different position... ... - .- -.
bertie1 Member Since: 30 Sep 2017 Location: kent Posts: 100 ![]() ![]() ![]() |
Cheers bud |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
You can use the earlier tow bar on the later vehicle - I have, when you remove the 2 black metal pieces from your car in order to fit the armature, you have to cut the brackets which have the exhaust hangers on them off and fit them to the bolts which secure the armature to the body. Your exhaust then hangs on these rather than the ones on the armature (which are in the wrong place as the earlier exhaust was slightly different. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
cheers sold it already now just a set of 19 alloys to go ! |
