Home > Technical (L322) > Is towbar bought for a 2004 the same fitting as a 2007 car
bertie1
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
Hi in process of selling a few bits and been asked if my tow bar from a 2004 vogue will fit a 2007 i understand the wiring is different but will the meatalwork fit cheers in advance
Post #481265 18th Jun 2018 1:25pm
the exhaust hangers will be in a different position... ... - .- -.
Post #481268 18th Jun 2018 2:05pm
bertie1
Cheers bud
Post #481295 18th Jun 2018 6:08pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
You can use the earlier tow bar on the later vehicle - I have, when you remove the 2 black metal pieces from your car in order to fit the armature, you have to cut the brackets which have the exhaust hangers on them off and fit them to the bolts which secure the armature to the body. Your exhaust then hangs on these rather than the ones on the armature (which are in the wrong place as the earlier exhaust was slightly different. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #481924 26th Jun 2018 7:23pm
bertie1
cheers sold it already now just a set of 19 alloys to go !
Post #481962 27th Jun 2018 9:34am
