Home > Technical (L322) > Help!!!!!!
VIRGIN
Help!!!!!!
Hi ALL,
Im new to the site and looking for some help please.
I had a fault pop up on my car saying the egr temp sensor had an open circuit. The car would come up with restricted performance, and eventually, your dpf is full, please visit dealer!!!!
Ive had the sensor changed, and it drove lovely for 10 miles and the back into limp mode.
It now has come up with codes telling me the mass airflow meter isnt working and low boost pressure. I would be grateful of any advice please?
Its a 2012 L322 4.4 TDV8
Post #480808 13th Jun 2018 7:29am
MattC
United Kingdom 2011 Range Rover Vogue SE TDV8 Alaska White
Check the top right rubber hose from the intake manifold. Take off the plastic engine cover and it the further towards the windscreen on the right hand side- they have a tendency to split. You should be able to either feel the split, or feel oil leaking out.
It's a DIY job to replace, but make sure you do all 4 hoses at the same time as they all degrade alarmingly quickly.
Post #480812 13th Jun 2018 8:23am
Baltic Blue
Number 1 Fault in my 4.4 tdV8 Fault history Log.
Mike.http://www.fullfatrr.com/forum/topic44115.html G reg 2.5VM Vogue Portofino red 1991- 1999
Post #480815 13th Jun 2018 8:42am
VIRGIN
Thank you for your replies, its been a great help
Post #480824 13th Jun 2018 11:42am
ajac8
welcome to the forum - stick around Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #480835 13th Jun 2018 3:51pm
VIRGIN
Thank you Thumbs Up
Post #480870 14th Jun 2018 6:47am
Baltic Blue
Well over 50 4.4tdV8 owners on here to help you by sharing experiences and knowledge.
Welcome to the club, and good luck sorting your problem.
Post #480871 14th Jun 2018 6:57am
VIRGIN
Thank you Mike, I'll post the solution as soon as I find it
Regards
Anthony
Post #480875 14th Jun 2018 7:50am
Baltic Blue
The original 4 hoses are very soft pliable rubber, but the replacements are much tougher.
They cost approx £100 for the 4 with new jubilee clips.
These are the replacements on mine.
Post #480883 14th Jun 2018 8:42am
the EGR open circuit is a ghost fault too. It crops up on several cars on here and there is pretty much a "they all do that" from time to time attitude from LR. I would doubt it is the cause of your fault. Much more likely to be boost related. While you have the engine cover off check and clean the MAP sensor on the intake plenum. Its the sensor with the red arrow pointing towards it on the pic above. It can get gunked up and give false readings of the pressure in the manifold. which can cause issues too. Bit of contact cleaner should clean it up. just take out the torx screw and the sensor pulls out.
Also give the MAF a clean with the contact cleaner, which may bring it back to life if it is that which is the problem, Check the hoses as above. I still have the original on mine as they haven't failed as yet but it is a weak spot.
If you aren't conversant in spannering then its time to learn. It comes in handy to fix the small problems which can be sorted on the drive in 20 mins rather than not have the car for a day or so while a garage sorts it out.
For example, I've just had Restricted performance on my Disco come up and 20 mins of spannering uncovered the problem and it was fixed with a securing nut from elsewhere in the engine bay from an area which was less critical! There is nothing that can't be fixed with a hammer😜😜
Post #480907 14th Jun 2018 4:16pm
DrRob
Where does one purchase said replacement hoses from chaps? Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #487373 28th Aug 2018 4:54pm
ask dan at duckworths in his section.
Post #487374 28th Aug 2018 5:01pm
Baltic Blue
Dan’s the man Thumbs Up
Post #487375 28th Aug 2018 5:04pm
DrRob
Great! Learning lots. Appreciate all the help and advice on here Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #487376 28th Aug 2018 5:04pm
Baltic Blue
http://www.fullfatrr.com/gallery/albums/us...G_1518.JPG
This photo shows a typical split. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #487377 28th Aug 2018 5:17pm
