Home > Technical (L322) > Front Fogs
Biggles1957
Front Fogs
So a while ago I started getting the 'check front fog lights' message. Not surprising because both were jiggered. Just changed both of them today and neither light up and still get the message when I switch the engine off. Strangely didn't get it when I started the car!
Any ideas? According to the handbook there is just one 5A fuse for 'lights' - that's all it says. Surely different lighting circuits are on different fuses??
Post #480774 12th Jun 2018 3:28pm
do you put your headlights on when you try? ... - .- -.
Post #480775 12th Jun 2018 3:30pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Not whilst lights set in auto. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #480776 12th Jun 2018 3:36pm
Biggles1957
Yes, headlights on. I don't have auto headlights (as far as I'm aware!). It's strange that I didn't get the 'check...' message when I turned the ignition on because I used to before changing the light units...
I've found a thread that explains how the lights all work via the module and it does look like there is only the one 5A fuse (number four I think) for all the lights so...
I'll have to get poking about with the multimeter it seems...
Post #480777 12th Jun 2018 3:40pm
