Home > Maintenance & Mods (L405) > 22" Wheel Bath & Removing Balance Adhesive
pld118
I'm a wee bit OCD about inner rims being as clean as the wheel faces and cannot abide scruffy wheel balance weight adhesive that gets left on inner rims after tyre changes.
I was looking for a container big enough to leave the wheels to soak to make the clean up process easier and less labour intensive
B & Q sell a £4 paddling pool that when filled with water will easily accommodate a 22" diameter wheel shod with tyre (if you have a compressor it's a doddle to blow up & deflate). Fill the pool with water, place the wheel inside and pour in a combination of Bilberry/ White spirit/ washing powder and then leave it to soak for a few hours. On return, using a microfibre/ net cloth the ugly balance weight adhesive comes off and the tar/ contaminants on the alloy easily clean up as new. Works for me 👍
If you do use the paddling pool, remember to either place it on grass or put padding underneath the pool base so you don't damage your wheel face if the pool is on a hard surface.
Post #480563 10th Jun 2018 8:28am
also ,remove small child from paddling pool when inserting wheel...
Mr. Green
a bit of useless info, i recently had my wheels road force balanced and part of the process is to make the wheels clean...the tyre chap scapped the old weights and old sticky stuff off and then placed the wheel into a steam cleaning machine...
the wheels came out spotless.. ... - .- -.
Post #480565 10th Jun 2018 8:38am
pld118
Whose information is useless Stan, yours or mine Embarassed
Actually, the steam cleaner is a point. I've got one of them. Will give that a go too Laughing
You'll be down at B & Q for Sunday opening time Stan! You know it Rolling with laughter
Post #480566 10th Jun 2018 8:39am
pld118
My other pet hate is alloys that get refurbished on the wheel face but the wheel/ inner rim hasn't been cleaned beforehand and you end up with a horrible brown film on the inner rim that is difficult to remove Rolling Eyes
Clean the wheel properly before having to refurb'd!
Post #480569 10th Jun 2018 8:45am
GGDR
Quote:
also , remove small child from paddling pool when inserting wheel...
or not and hand the child a brush....
Razz Cheers, Greg
Post #480571 10th Jun 2018 9:09am
Shocked
I gave my car a quick once over in April as it hadn't been done since November.
French motorways in the warmer weather are a nightmare for insects and my windscreen is now plastered - when I clean it later, I might do the rest of the car at the same time Whistle
BTW - I don't have the sticky weights problem - when I needed new tyres (6 weeks ago), I bought new wheels too - I keep meaning to clean the old set and advertise them Embarassed
Post #480572 10th Jun 2018 9:33am
re cleaning the bugs off the windscreen, i use normal water and an old face cloth and just rub the bugs off..works well..
@ryan, i was on about my useless info Wink ... - .- -.
Post #480576 10th Jun 2018 10:28am
Will give it a try - I have a 'bug shifter' sponge, but I'm always worried it will scratch the screen.
I was hoping it might rain and soften things up, but I might have to get the hose out Rolling Eyes
Post #480595 10th Jun 2018 1:43pm
