Home > Technical (L405) > Odd Random significant vibrations at high speed
United Kingdom 2017 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
My wife's RR L405 Supercharged (63 plate) has suddenly started to vibrate randomly.
The first occasion on the M11 I assumed it was a road surface issue but eventually pulled over to the hard shoulder and after checking tyres okay I pulled away and it had gone.
It's now happened twice more on the M40, second time it happened I had to pull over twice as the first time it didn't solve the problem.
It's been to two garages from the warranty company and neither really have any idea.
They say can't be wheel balance or prop as it would happen all the time.
It normally happens when travelling at about 85mph in the cruise and after about an hour or so but equally you can drive for 2/3 hours and not have anything.
Anyone have any ideas, the car did about 3 months ago pop up with a huge gear box error and lots of warning light but on turning off and restarted they all disappeared.
Thanks
Post #479346 25th May 2018 10:43am
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Annoying and very distracting!
In a strong headwind mine can sometimes make a resonant buzzing/vibrating noise from the mid-upper screen area. I've examined all the screen sealing areas, airbox, etc but can't eliminate it. Once I'd figured out what it was, though, i became more relaxed about it.
A few questions about your situation, if I may, to tease out some more details:
Can you detect where the vibration is coming from?
Is the nature of the vibration one that you more feel than hear or vice verse?
If you increase or decrease speed does the vibration change or disappear?
Have you tried changing gear manually to see if the vibration disappears?
Does opening a window or manipulating the ventilator on controls have an effect?
Have you checked or tried varying your tyre pressures? 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #479479 27th May 2018 11:21am
DJ
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Have you had the engine mountings checked? I would. It's an expensive repair, hence why Warranty and Dealers are often coy about taking this repair on.
Post #479580 29th May 2018 8:58am
bear100
I have had the very same issue, also taken it to two dealers and they are both none the wiser, its random as you say, firsyt it only started at high speed but now it has started at lower speeds around 50/60 mph
Every time i had taken the workshop engineer out for a test drive but Sod’s law it stopped.
I am going to take it back soon 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #479720 30th May 2018 6:33pm
Sorry my answers below, I wasn't notified of any replies on the topic so forgot to check back:
Can you detect where the vibration is coming from? - No, it's not apparent to me.
Is the nature of the vibration one that you more feel than hear or vice verse? - More hear to start, there isn't huge vibration but once it's vibrating it just carries on and is very noticeable.
If you increase or decrease speed does the vibration change or disappear? - No it won't go away until the car is stationary and then one one occasion it start again as soon as I drove off so I had to stop again.
Have you tried changing gear manually to see if the vibration disappears? - No but will do.
Does opening a window or manipulating the ventilator on controls have an effect? - Don't know will ty.
- No I haven't, I do have one tyre with a very very slow leak so that one I pump up every couple of months.
The one thing I do also think is new is the car makes creaking noises at low speed when parking which I don't recall it made before.
Post #480097 4th Jun 2018 10:16am
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Had a similar problem was driving me mad thought torque converter.drive shafts.gearbox etc turned out to be a bulge in the tyre across the tread hardly noticeable but when I put new tyre on all was good . perelli scorpion verde all weather around 4/5mm did not show up when balancing hope this helps
Post #480147 4th Jun 2018 8:24pm
So just to update anyone who might be interested, I think the vibration was being caused by a failing tyre. That slow leak turned one day into quite a bit leak and we have to pull over and most of the inside tyre wall was torn. Pretty alarming really that this can happen.
Must say the 22" tyres are just a PITA, I've gone through so many of them failing, punctures etc... 1994 Range Rover LSE Autobiography
1994 Range Rover Vogue LSE Softdash
1994 Range Rover Vogue LSE (transmission failed so now a donor car!)
1994 Range Rover Vogue LSE (knackered donor car!)
1993 Range Rover Vogue LSE
1969 Aston Martin DB6 Vantage
1953 Lagonda DB3.0 Drophead Brooklands
1939 Lagonda LG6
Post #523520 1st Aug 2019 3:32pm
pherplexed
United States
Had a very similar random vibration on my wife's Audi Q7 at certain speeds. Turned out to be a cracked radial belt in the tire. Nearly impossible to spot with my untrained eye b/c the tire surface looked perfectly normal. Replaced the tire and all was fixed.
Post #523535 1st Aug 2019 6:42pm
