Home > Maintenance & Mods (L322) > mot failure
reynolds
England 2004 Range Rover Autobiography Td6 Buckingham Blue
mot failure
hi my 2004 vogue has failed its mot on osf outer cv gaiter and rear hand brake efficiency what is involved is it beyond a competent home mechanic
Post #49716 11th Feb 2011 1:45pm
dan_uk_1984
I hope they didnt test your HB on a rolling road:
http://www.fullfatrr.com/forum/topic4570.html
Regarding your gaiter, you have to buy the inner and outer boot together which is a bit of a pain:
http://www.island-4x4.co.uk/driveshaft-boo...-3516.html
I paid a garage an hour's labour to fit mine as it's a nasty messy job to do on the drive, the greas in there is horrible stuff. So expect to pay no more than £100 inc parts & labour for that.
The HB can be adjusted very easily:
http://www.fullfatrr.com/forum/topic531.html
Or if you need to replace the shoes, I paid £70 inc parts & labour for this.
D
Post #49725 11th Feb 2011 2:47pm
Get the garage to fit the soft flexible rubber boot, they are much easier to work with and don't require the drive shaft to be stripped down for fitting
Post #49729 11th Feb 2011 2:59pm
reynolds
mot failure
thanks for your advise they did the brakes on the road i just wanted to know if you have the front air suspension de pressurised before removing the front hub to do the drive shaft boot thank you
Post #49759 11th Feb 2011 5:24pm
No need to de-pressurise the suspension, you'll need a 36mm bi-hex socket for the hub nut and removing the shaft from the hub will be very tight
Post #49760 11th Feb 2011 5:31pm
reynolds
mot failure
thanks for the advise much appreciated
Post #49762 11th Feb 2011 5:54pm
Dan,
The link provided above no longer works - any ideas?
Post #52278 1st Mar 2011 9:18am
Martin
Site Admin
Thread now back in place Thumbs Up
Post #52301 1st Mar 2011 12:04pm
Thanks Martin.
Just back from 1st MOT on the latest TDV8 and they used the decelerometer in the car park and job done in 5 minutes and no rolling road. They tested the ebrake but not with the car moving so quite sensible really.
Gary
Post #52309 1st Mar 2011 1:25pm
