Home > Maintenance & Mods (L322) > mot failure |
reynolds Member Since: 07 May 2010 Location: great yarmouth Posts: 83 |
hi my 2004 vogue has failed its mot on osf outer cv gaiter and rear hand brake efficiency what is involved is it beyond a competent home mechanic |
11th Feb 2011 1:45pm |
I hope they didnt test your HB on a rolling road:
11th Feb 2011 2:47pm |
thanks for your advise they did the brakes on the road i just wanted to know if you have the front air suspension de pressurised before removing the front hub to do the drive shaft boot thank you |
11th Feb 2011 5:24pm |
No need to de-pressurise the suspension, you'll need a 36mm bi-hex socket for the hub nut and removing the shaft from the hub will be very tight |
11th Feb 2011 5:31pm |
thanks for the advise much appreciated |
11th Feb 2011 5:54pm |
Dan,
1st Mar 2011 9:18am |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1666 |
Thread now back in place |
1st Mar 2011 12:04pm |
Thanks Martin.
1st Mar 2011 1:25pm |
