Home > Technical (L322) > 4.4TDv8 cap on oil extraction pipe
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
My car has no cap on the pipe used for extracting the engine oil.Is this correct?The D4's I looked at all had a cap(cover)on the oil pipe.What has your 4.4 TDv8 got?Is it covered? 2012 TDV8 Vogue SE 4.4
Post #478084 11th May 2018 7:48pm
dolph34
Mine has one and I would of assume yours should too. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #478086 11th May 2018 7:51pm
Should have a cap. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #478087 11th May 2018 7:53pm
Frans@Yamorna
Thumbs Up Thumbs Up What I thought!! 2012 TDV8 Vogue SE 4.4
Post #478088 11th May 2018 7:53pm
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
Hi, I have the same problem.
Land Rover quote replacement of Scavenge pipe assembly LR043286 at £130.
Does anybody have a spare cap or know how to get one?
http://www.fullfatrr.com/gallery/albums/us...2211~0.jpg RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #540674 15th Jan 2020 2:40pm
Baltic Blue
Get a short piece of plastic tubing like in the picture in the last post, then find a suitable size bolt to fit in the end and blank it off. That will do the job.
Post #540678 15th Jan 2020 3:17pm
Frans@Yamorna
Same as D4/RRS.Breaker yard? 2012 TDV8 Vogue SE 4.4
Post #540679 15th Jan 2020 3:18pm
