![]() | Home > In Car Electronics (L405) > Retrofit Security |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
Mod - unsure why you have moved this thread from the General forum but left the Autowatch Ghost thread in the General forum? They would be best located together in my opinion.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
both threads moved to this section.. |
If you are looking for a simple and reliable means of stopping someone driving off in your car I don't reckon you will find anything better than a concealed switch interrupting the electrical supply to the fuel pump relay. Old as the hills but tried and tested. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
A very low tech approach to preventing signal boosters allowing someone else to open the car e.g. outside your house is to put the keys into faraday cages - I tried folded up aluminium (kitchen) foil and that worked.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Good call - I’m going to take a look and see if there is a suitable fuse I could wire a piggy back switch into ![]() One of the advantages of living in a flat is that my keys are a long way from the car, but having just bought a house, I’ve started thinking about this problem again. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Cutting the fuel supply on any diesel can lead to problems if it is necessary to prime the system to clear air when the supply is restored. ??
I’m also thinking about the times I leave the RR in public car parks (airport/railway) sometimes for weeks at a time. I’d like to increase the likelihood that it’s still there when I return. Based on what i’m reading I don’t think there is a retrofit tech solution. Might have to consider a physical solution for the times I leave it for a while. MY23 D350 HSE
This might be an option.
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
What we need is that when we spend around 100k for a car that it comes with a security system that works. letters not necessarily in the right order |
if you want extra security then nicedayforit's kill switch is the way to go but i wouldnt like to get the info on where and how to fit it here on the forum..
Thanks Stan MY23 D350 HSE
If your car is still under warranty, have a good look at the warranty terms before proceeding, I have a recollection that making changes not authorised by LR can void the warranty. Q whether the installer of the switch will cover any loss there might be due to not having the LR warranty? My guess is you'd be on your own. Only Range Rovers since 1988 |
