Home > Technical (L322) > Motorway suspension setting
johnspex
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Yesterday I did 300 of miles on all sorts of roads. The car ,naturally, rolls a lot on B road corners.
If I get it up to motorway speeds and the suspension lowers can I press the suspension button and keep it lowered without damaging anything as it just makes it nicer?
Thanks.
Post #476992 28th Apr 2018 6:16am
Paul thornton
No it will raise itself at 25mph even if you have it locked. It will just give you a warning first.
However, you can lower them to your desired height but you will need an IID tool.
Post #476998 28th Apr 2018 7:26am
johnspex
IID tool?
Post #477002 28th Apr 2018 8:01am
Paul thornton
GAP diagnostics IID tool.
They are site sponsers on here.
Post #477003 28th Apr 2018 8:03am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I’m not familiar with the running gear on the L322 but, in general, I’d be concerned about the angle that the joints in your drive shafts will be running at.
Running in high and low occasionally is one thing, running it at a slightly odd angle for a long period at high speed may well be another Confused
https://mechanics.stackexchange.com/questi...ive-shafts
Post #477013 28th Apr 2018 9:47am
Paul thornton
Mines been running 15mm lower for the the last 6months or so without any issues.
It's a little harsher than standard but well worth the sacrifice for looks and driveability.
Post #477017 28th Apr 2018 10:36am
Mine stays at motorway height if I press inhibit. Maybe it works for pre 2006 models ? .
Post #477019 28th Apr 2018 10:55am
Red Merle
Unfortunately, simply lowering a car does nothing to improve the handling.
If you lower it enough to make any difference, any reduction in the C of G is more than offset by cocking up the suspension geometry anyway Wink
Post #477022 28th Apr 2018 11:16am
johnspex
Surely it wouldn't be an odd angle merely the angle at which it runs at high speed for maybe hundreds of miles in motorways.
I thought mine stayed in the low motorway position too.. Certainly the motorway light stayed on.
Post #477077 29th Apr 2018 9:12am
