![]() | Home > Technical (L322) > Motorway suspension setting |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
No it will raise itself at 25mph even if you have it locked. It will just give you a warning first.
johnspex Member Since: 18 Mar 2018 Location: North Devon Posts: 18 ![]() ![]() ![]() |
IID tool? |
GAP diagnostics IID tool.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
I’m not familiar with the running gear on the L322 but, in general, I’d be concerned about the angle that the joints in your drive shafts will be running at.
Mines been running 15mm lower for the the last 6months or so without any issues.
Mine stays at motorway height if I press inhibit. Maybe it works for pre 2006 models ? .
Unfortunately, simply lowering a car does nothing to improve the handling.
Surely it wouldn't be an odd angle merely the angle at which it runs at high speed for maybe hundreds of miles in motorways. I thought mine stayed in the low motorway position too.. Certainly the motorway light stayed on. |
