Home > Maintenance & Mods (L322) > Can’t get rear wiper down to change blade
Jmattbdl
United States 2011 Range Rover Supercharged 5.0 SC V8 Rimini Red
For some reason I cannot get the rear wiper in the down position to change the blade. I have a 2011 range rover SC.
I have tried turning car off when wiper is down & I’ve even tried the start/stop then start/stop, then start/stop while holding the wiper control arm in down position, the front wipers stop mid window but not the rear??? Anyone else had this problem? Can someone help me with the solution? Is there some other method I don’t know about?
Post #476384 21st Apr 2018 2:07am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Have a look here, see if that helps
http://www.fullfatrr.com/forum/post450899.html#450899 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #476390 21st Apr 2018 7:08am
Tooltime79
Not sure if this is he official way but I did mine by leaving the bottom tailgate open and then letting the top part close to trick the car into thinking it is all closed. Turn on car and start the rear wiper. Go to the back and as the wiper is moving, lift up the rear tailgate and it will stop. Go back and turn off of action whilst tailgate is up. Wiper will then stay down for you to change the blade!
Post #476391 21st Apr 2018 7:12am
bishbosh10
Turn on rear wiper.
Press tailgate release button at the appropriate juncture.
Change wiper blade Very Happy
Repeat until you get it to stop in the right place! Rolling with laughter Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #476398 21st Apr 2018 8:38am
Jmattbdl
Got it, thanks for all the replies.
Post #476407 21st Apr 2018 11:45am
