Home > Technical (L322) > Annoying squeak /squeal |
Dave Member Since: 03 May 2016 Location: Norfolk Posts: 187 |
Was driving home the other day, I was driving for about an hour so the car was warm. I heard a intermittent squeal, though I thought the squeak was from the car in front, until it turned off, then I opened my window and discovered it was me.
12th Apr 2018 10:17pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 334 |
Sounds very much like what I had. Turned out to be a seized caliper. |
12th Apr 2018 11:10pm |
Thanks mate, did you just clean the caliper or replace it? Dave
12th Apr 2018 11:12pm |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
I had a similar problem, but didn’t resolve it in time and ended up with a warped disk. My sticking pads were due to the corrosion on the calliper carrier. Remove the carrier file back the area where the the pads rest on the calliper carrier to remove all of the rust and use CeraTec on those surfaces. Don’t be shy in filing back to remove all the rust, I ended up having to strip down a second time.
13th Apr 2018 7:25am |
I ended up replacing, disk, pads and calipers. Hope yours is an cheaper fix. |
13th Apr 2018 10:31am |
Thanks for the replies guys. As it's only just started and I've only driven the car for a few miles since, i'm hoping i can resolve it with too much expense. Dave
14th Apr 2018 1:42am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
The rear calipers aren't expensive , too think i paid 50ish for one on my 3.6. 2015 4.4 AB
14th Apr 2018 8:39am |
Sadly the larger Bembo set up on the 4.4TDV8 means the exchange rear calliper are around £170 each |
14th Apr 2018 9:31am |
D'oh, cheers for the bad news lol Dave
15th Apr 2018 1:05am |
