Home > My Range Rover > I love my Range Rover - Still
dan_uk_1984
The check engine light keeps coming on, so I clear it daily.
The header tank weeps a bit.
There is a slight knocking/clunk at the front.
The rear wiper doesn't work when its cold.
When the wiper does work sometimes it gets stuck and needs to be reset.
The battery needs replacing as its let me down twice this year.
The mudflaps don't quite fit flush against the body.
The side step trim is cracked.
The thumb-wheel drives me crazy.
And the mirrors are slightly loose so they wobble back and forth.
All that being said, I still love her!
Banging Head
Post #49215 7th Feb 2011 1:09pm
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
My front mud flap don't seem to fit next to the wing flush since i had a tyre change. Did wonder if they had jacked the FF from the wrong place but not had chance to check them.
Post #49216 7th Feb 2011 1:18pm
my smax never went wrong in two years , totally boring experience...at least the RR keeps you entertained with its quirks and problems and mostly , a lovely drive..... ... - .- -.
Post #49222 7th Feb 2011 1:35pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
yep, I've had mine for just over 2 months and already had a list of issues. (thankfully all has been sorted under warranty). This weekend I went to leave my dads & bros garage only for the battery to decide it was going on strike. 2 hours later after a charge and with everything reset she was good to go again. Its all part of the Range Rover experience Smile FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #49231 7th Feb 2011 3:42pm
comports
HI Greg - I have heard that if it only takes 2 hours to charge your battery then it's probably nearly dead. It will charge up quickly but discharge even quicker. Word of advise - "Don't use the FBH if you have one". That's sure to kill it for you.! Smile Ash
2016 SDV8 AB
Post #49244 7th Feb 2011 4:43pm
GregP
Don't think I have a fbh. Would I know if I did?? (apologies for my stupidity)
But yes, I reckon the battery is on it's last legs. FFRR TD6 HSE
Post #49250 7th Feb 2011 5:09pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Still top mine up with coolant everyweek.
Bonnet release still a set of mole grips.
I love my Range Rover too, looks lovely all valeted up outside my window. 15MY SDV8 Vogue SE
Post #49251 7th Feb 2011 5:20pm
dan_uk_1984
Shocked The FBH has no ill effect on a healthy battery. Although if your battery is on its way out then you may wish to limit it's use. But when working the FBH actually has very little draw on the battery as it burns fuel to heat and just runs a small coolant pump.
Post #49252 7th Feb 2011 5:29pm
dan_uk_1984
You do have a Fuel Burning Heater, but probably dont have the remote and reciever for it.
See the WiKi and Fuel Burning Heater for more info:
http://www.fullfatrr.com/wiki/Main_Page
Post #49253 7th Feb 2011 5:34pm
GregP
Thanks Dan. Does that link provide info on how to get the remote and reciever? FFRR TD6 HSE
Post #49257 7th Feb 2011 5:48pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
mines running sweet.
one front headlight wiper and the rear wiper jet dont squirt.
thats it.
....bong of death coming now i said that... Laughing 2004 black Vogue TD6
Post #49259 7th Feb 2011 5:53pm
dan_uk_1984
Click it?
Post #49268 7th Feb 2011 6:29pm
GregP
Yep, again apologies for my stupidity. I'll work it out. FFRR TD6 HSE
Post #49271 7th Feb 2011 6:42pm
dan_uk_1984
GregP wrote:
I'll work it out.
If you need help on it, it's worth posting on the original thread (listed in that wiki article) as there are a lot of posters on there, some who have already looked at what is needed.
Do you have the loose plug in the boot (right hand side panel)? You may already have the receiver fitted?
You can buy an off the shelf kit apparently:
http://www.parkingheater.co.uk/fileadmin/u...adekit.pdf
Post #49276 7th Feb 2011 6:56pm
GregP
I do remember seeing something in the boot. I'll take a proper look tomorrow and then look into what I need to get it working. Thanks again mate. FFRR TD6 HSE
Post #49281 7th Feb 2011 7:14pm
