Home > My Range Rover > I love my Range Rover - Still |
The check engine light keeps coming on, so I clear it daily.
7th Feb 2011 1:09pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
my smax never went wrong in two years , totally boring experience...at least the RR keeps you entertained with its quirks and problems and mostly , a lovely drive..... ... - .- -.
7th Feb 2011 1:35pm |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
yep, I've had mine for just over 2 months and already had a list of issues. (thankfully all has been sorted under warranty). This weekend I went to leave my dads & bros garage only for the battery to decide it was going on strike. 2 hours later after a charge and with everything reset she was good to go again. Its all part of the Range Rover experience FFRR TD6 HSE
7th Feb 2011 3:42pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1721 |
HI Greg - I have heard that if it only takes 2 hours to charge your battery then it's probably nearly dead. It will charge up quickly but discharge even quicker. Word of advise - "Don't use the FBH if you have one". That's sure to kill it for you.! Ash
7th Feb 2011 4:43pm |
Don't think I have a fbh. Would I know if I did?? (apologies for my stupidity)
7th Feb 2011 5:09pm |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 |
Still top mine up with coolant everyweek.
7th Feb 2011 5:20pm |
The FBH has no ill effect on a healthy battery. Although if your battery is on its way out then you may wish to limit it's use. But when working the FBH actually has very little draw on the battery as it burns fuel to heat and just runs a small coolant pump. |
7th Feb 2011 5:29pm |
You do have a Fuel Burning Heater, but probably dont have the remote and reciever for it. See the WiKi and Fuel Burning Heater for more info: http://www.fullfatrr.com/wiki/Main_Page |
7th Feb 2011 5:34pm |
Thanks Dan. Does that link provide info on how to get the remote and reciever? FFRR TD6 HSE
7th Feb 2011 5:48pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
mines running sweet.
7th Feb 2011 5:53pm |
Click it? |
7th Feb 2011 6:29pm |
Yep, again apologies for my stupidity. I'll work it out. FFRR TD6 HSE
7th Feb 2011 6:42pm |
If you need help on it, it's worth posting on the original thread (listed in that wiki article) as there are a lot of posters on there, some who have already looked at what is needed. Do you have the loose plug in the boot (right hand side panel)? You may already have the receiver fitted? You can buy an off the shelf kit apparently: http://www.parkingheater.co.uk/fileadmin/u...adekit.pdf |
7th Feb 2011 6:56pm |
I do remember seeing something in the boot. I'll take a proper look tomorrow and then look into what I need to get it working. Thanks again mate. FFRR TD6 HSE
7th Feb 2011 7:14pm |
