Home > In Car Electronics (L322) > Radio not working Water ingress |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35438 |
hopefully it will dry out...
28th Mar 2018 4:43pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
You really need to remove the dsp, Satnav and tv module and put them in an airing cupboard for a couple of days to dry out. You may be lucky they may start to work again. The radio module can be left in place initially, it tends not to get wet.
28th Mar 2018 5:28pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 |
Also put some silicone around rear tailgate hinges where they attach to the body of car and I had a leak via the sat nav roof mounted aerial so I ran a bead of silicone round this also now all good....I have some slight water ingress in spare wheel well but have no idea where this is getting in.... Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
13th Apr 2018 11:45am |
