Home > In Car Electronics (L322) > Radio not working Water ingress
markyp
England 2004 Range Rover Vogue Td6 Zambezi Silver
Afternoon gentleman, Jumped in the car today after it had been raining all day, There was a crackling kind of noise coming out of the speakers and no radio, opened up the compartment in the rear of the car on the n/side were the sat nav and amps are located, it was soaking wet, water was dripping of the holder for the DVD for the sat nav. I haven't used the car for a couple of days so must be due to recent downpour, Any ideas TIA Mark 2004 vogue
1978 Pontiac Firebird
2010 Fiesta
Post #474177 28th Mar 2018 4:25pm
hopefully it will dry out...
you'll need a 'water shedder' ..loads on this ,do a search..
and you'll need to check the tailgate rubber seal to make sure the water isnt coming via that. ... - .- -.
Post #474180 28th Mar 2018 4:43pm
You really need to remove the dsp, Satnav and tv module and put them in an airing cupboard for a couple of days to dry out. You may be lucky they may start to work again. The radio module can be left in place initially, it tends not to get wet.
Once you have the bits out you may need to mop up water from the bottom of the compartment and dry it out. It would also be worth looking below your spare wheel to see if water has accumulated there. Whilst all the bits are out it is worth checking the various plugs for corrosion.
As Stan says you need to look to the upper tailgate seal particularly the top near side corner, that's the usual problem area. It may need to be replaced, very common problem.
Once you get all the bits back in you can only hope everything works again. If not, no doubt you will be back. Thumbs Up
Post #474185 28th Mar 2018 5:28pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Also put some silicone around rear tailgate hinges where they attach to the body of car and I had a leak via the sat nav roof mounted aerial so I ran a bead of silicone round this also now all good....I have some slight water ingress in spare wheel well but have no idea where this is getting in.... Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #475688 13th Apr 2018 11:45am
