Home > Technical (L405) > Burning Rubber Smell
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I've noticed a strong burning rubber smell after longer journeys in my SDV8 L405. I can't smell it in the cabin but as soon as I get out of the car there's a strong smell that appears to coming from underneath the car near the rear passenger area. The smell doesn't appear after short journeys.
I've read the previous post regarding burning smells but these all appear to be L322 model related. Has anyone experienced anything similar on an L405? 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #474139 28th Mar 2018 10:54am
touch the wheel after the long journey and see if the wheel is hot..it could be a sticking caliper.. ... - .- -.
Post #474143 28th Mar 2018 11:41am
Chalky
Burning rubber?....those were the days!!! Rolling with laughter Rolling with laughter
Post #474161 28th Mar 2018 1:46pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Yes, I’ve had it on mine too. I did check all the calipers straight away and they were all cool. I’ve had the same thing on at least one of my late D4’s. It never seems to have caused a problem.
I had recently heard it suggested that it was a by product of a DPF regeneration cycle..,
Post #474198 28th Mar 2018 8:20pm
Edgey808
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Hi All,
I’ve been driving locally for a few hours and noticed a burning rubber smell inside the car, I’ve checked all the alloy wheels, and these are all fairly cold. No leaks underneath the car, popped the bonnet and it just smells like a hot Diesel engine ? No smell of burning rubber?
Do we still think this smell could be the dpf regeneration?
Any help appreciated....
Stephen
Post #575583 9th Dec 2020 5:44pm
knwatkins
I think the DPF regen sounds like a plausible explanation. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #575594 9th Dec 2020 8:48pm
Or a leaking engine oil cooler? They leek onto the exhaust and STINK!!! Worth a check Thumbs Up
Post #575606 10th Dec 2020 12:07am
DrRob
Leaky oil cooler was my first thoughts...get underneath and see if any oil on rear edge of engine under tray first. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #575612 10th Dec 2020 8:36am
diesel Dave
Agree with Dr Rob and Craig, done quite a few of these and they do stink a bit.
Post #575615 10th Dec 2020 9:05am
Edgey808
Thanks all I will have a look to see if there are any leaks?
Post #575625 10th Dec 2020 10:02am
Edgey808
Only had a quick look this morning, I’ll have more time at the weekend.
Found this wet area looking down with the engine cover removed.
Is this looking like the typical oil cooler issue?
Also found some wet area around this component? Not too sure what it is at the moment?
Thanks again for your help....
Stephen.
Post #575654 10th Dec 2020 2:06pm
Edgey808
Ok so after further investigation, I have a very small leak from the oil cooler gasket 😖 (as you predicted.) currently ordering the recommended seals / gaskets as per other the other threads on the subject.
Thank you very much for the advice, it really does make ownership of these great cars much easier👏🏻👍
I’ve got access to a two post lift during the Xmas period so will hopefully fix this issue and investigate another 🤔
Thanks
Stephen
Post #576425 17th Dec 2020 10:07am
